JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
R53 JCW Boost Pressure
  #26
Old 09-20-2018, 08:06 PM
OCR's Avatar
OCR
OCR is offline
Along with the various cam designs (overlap differences), the "location" of the gauge tap will also alter not only the overall boost number, but also the sensitivity of the needle movement. Everyone tapping from different locations is like measuring green apples to red. Still apples...just different.
As another did, I also tapped off of the "down tube", after the intercooler, (don't know the actual name of the cast tube). The trapezoidal block (machine stop) on the casting is a perfect place if not taking the front of the car apart to get at the intake manifold. Grind the casting flat, about .040" above the main surface. Make a diaper to catch chips. Drill - tap for an 1/8" pipe thread. Tap it deep enough so that minimal air is disturbed inside the tube when the fitting is installed. Install a 90 degree fitting, install the nylon tube fitting into that...connect to the gauge.
That tube or the intake manifold itself is the best/most accurate place to tap off of.
Also, for this discussion, the more exhaust system back pressure, the higher the intake pressure will read. More freer flowing exhaust systems, will show slightly lower intake system pressures. Kinda falls right behind the way the cam effects system pressures.
So again, comparing intake systems (blower boost) pressures, one car to another...just doesn't work. Most everyone's combinations are...different..!
Mike
  #27
Old 03-03-2019, 11:06 AM
flatlander_48's Avatar
flatlander_48
flatlander_48 is offline
Does anyone know what the boost pressure is limited to by the factory for Gen 1 S models? Does that change with the Gen 1 JCW package?
I know what the factory boost pressure limits are for the Gen 2 S and JCW models, but I am curious about Gen 1 and Gen 3 cars...
  #28
Old 03-03-2019, 03:48 PM
Revolution Motor Works's Avatar
Revolution Motor Works is offline
Vendor
Originally Posted by MrBlah
My JCW is bone stock and I see just a tad over 11 psi
it's because your blower is dead
  #29
Old 03-03-2019, 03:57 PM
MrBlah's Avatar
MrBlah
MrBlah is offline
6th Gear - AX Champion
could be? I thought that was normal for a factory jcw setup, but I'm not worried about it, no abnormal noise and no wear noticeable when I changed the oil
  #30
Old 03-03-2019, 04:02 PM
Vendor
13.5psi is normal anywhere near sea level. You can do the calcs for altitude
  #31
Old 03-03-2019, 04:08 PM
MrBlah's Avatar
MrBlah
MrBlah is offline
I might have got my cars mixed up, no boost gauge on it to tell now
  #32
Old 03-06-2019, 12:31 PM
Oldboy Speedwell's Avatar
Oldboy Speedwell
Oldboy Speedwell is offline
I was finally able to read boost this afternoon as I got a quality OBD bluetooth dongle and used the Torque app.
I'll be putting in an analog boost gauge in the near future though.
My max reading was 15.8psi.
2006 JCW with stock pulley, 2% WMW crank pulley, Detroit Tuned bpv
Would be curious to hear people vacuum readings also.
At idle mine fluctuates between 19.0 - 19.6 inHg
  #33
Old 03-13-2019, 07:11 PM
Usmcxd's Avatar
Usmcxd
Usmcxd is offline
So...bluetooth and torque app, the highest I normally have is just over 12. When I went "down the hill" to sea level, I was close to 14; unfortunatly i wasnt logging so i dont know what it actually was.
2004- 200 JCW
mods-back of airbox cutout
Cravenspeed lightweight 0% pully
VGS mod
114k on the clock
  #34
Old 03-19-2019, 06:28 AM
JABowders's Avatar
JABowders
JABowders is offline
I think anything at or over one BAR (14.7 psi) or if you are a pilot you recognize it as (29.92 inches) is great..
For more usable pressure I'm a +1 for hoses and clamps.
Motor On!
stardust88
07-06-2019 10:44 AM
garthg
10-25-2014 09:01 AM
WLSH BST
12-20-2013 07:03 PM
Headlands
R55 :: Clubman Talk (2008+)
04-02-2010 02:23 PM
davydo
06-12-2008 12:35 PM
Quick Reply: R53 JCW Boost Pressure
