-1.25 camber+wheel studs=brake noise?
Last Friday i had some Ireland Engineering fixed camber plates and there wheel stud kit installed on my 06 JCW. The car feels great but now the brakes are making a ton of noise. Sounds like the pads are not retracting and are rubbing on the rotor. Doesnt seem to slow the car down but the noise is epic. Anybody ever run into a similar issue? Thanks!
Yea, sounds like an installation problem.
The parts you have, on "their" own will not cause any problems.
I installed studs some time back with no problems. I have a pair of Ireland adjustable plate's I've yet to install, but see no problem in doing so.
Per the previous post, check ALL parts clearances, wheels to, tires to, brake line to, caliper bracket to, caliper to...etc., etc.
Mike
Mike
UW Mitch
Wheels/Tires/Brakes
11-12-2017 11:42 AM
JWA
03-24-2016 06:52 AM
