jcw 2005
jcw 2005
Does anyone have an idea when the 2005 up grade kit will be available for older works models in the u.s.? i spoke with my dealer according to the sales dept. sometimes in january and accoding to the service manager the up grade alone will not be marketed for the us market!!! plus any information regarding the 2005 works suspension will be greatly appreciated.
many tnx
many tnx
Originally Posted by miniaq
anyhow if i undrestand correctly with the new air intake no performence increase is seen below? is this also the case with the after market intakes?
JCW stated in an email to me that additional air flow is not required until 4500 rpm, although I've read that this may have something to do with ensuring the intake meets worldwide noise regualtions:
http://www.mini2.com/forum/showthrea...44#post1113944
Removing the partition between the engine bay and cowl area as required for installing the Alta intake or cutting holes in the partition is going to make for more noise, but I don't think anyone has substantiated how much additional power is gained by allowing more air flow from the cowl area.
Originally Posted by MINIAC
Assuming you are refering to the JCW intake system not opening the "flap" to allow additonal air flow from the cowl area until 4500 rpm:
polotska
08-23-2015 09:10 AM
