JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW heads - any differences between years?
Old 01-10-2017, 10:49 PM
Paul's Avatar
Paul
Paul is offline
I have an 06 that I'd like to add a JCW head to. I found a JCW head from an 04 that's been cleaned and tested. I'm wondering if heads changed from the 200 HP version of the JCW kit to the 210 version on the 05/06 models. Will the 04 head fit an 06?
thanks, paul
Old 01-11-2017, 04:42 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Whine not Walnuts is offline
Pretty sure the heads are the same, the injectors changed to 380s for 05/06.
Old 01-11-2017, 07:17 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
All the R53 JCW heads are the same 2002-2006 so you can install it no problem.
If it was in my shop I'd make sure to put new exh valve guides in it as these wear out all the time and much cheaper to do now rather than later.
Also good time to add our WMW mild cam as the labor will be free
https://www.waymotorworks.com/way-mi...t-r52-r53.html
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
Old 01-12-2017, 02:56 AM
ItsmeWayne's Avatar
ItsmeWayne
ItsmeWayne is offline
WayMotorWorks is spot on. Do it before you go any further. Now is the time to do it and have the head checked for straightness. You don't want a head gasket issue.
Old 02-03-2017, 11:19 PM
Paul's Avatar
Paul
Paul is offline
Thanks guys for the info! I've got the head in the shop now. It'll get new stem seals, guides, new surface, etc.
Old 06-21-2018, 05:47 PM
jjcsnlynn's Avatar
jjcsnlynn
jjcsnlynn is offline
Do the exhaust valve guides wear out all the time in the JCW and R53 or just JCW?
Old 06-21-2018, 08:35 PM
downshift1's Avatar
downshift1
downshift1 is offline
All the guides wear out.
Don't waste your money on a JCW head, it's not worth it. The minor shallow port job on the exhaust side only does not justify the price.
Take your money and your head and send it off to Thumper and you see a much bigger return on your investment.
Old 06-22-2018, 08:40 PM
WayMotorWorks
Vendor
Yes. More so if running low octane gas.
Old 06-23-2018, 09:02 AM
pnwR53S's Avatar
pnwR53S
pnwR53S is offline
6th Gear - NAM Hall of Fame
Could it be even worst if running low octane gas and have an aggressive tune? The truth is I have very little idea what constitute an aggressive tune. My guess is too much ignition advance, and or too little injector. Somebody please school me.
Old 07-03-2018, 09:02 AM
downshift1's Avatar
downshift1
I've had conversations with half a dozen machinists after showing them a R53 head.
It's actually a few compounding issues. The two major ones they noted are:
The craptastic guide clearances in the head from the factory. (Yes I still have a brand new OEM head)
Side loading of the valve due to a horribly designed rocker set-up that flexes and moves under hard use.
Can you prevent it? Sure, toss some good guides and valves with proper clearances in and pick up Jan's billet rocker set up and it'll fix most of the issues
Old 07-15-2018, 10:47 PM
OCR's Avatar
OCR
OCR is offline
downshift -
Please explain..."craptastic". This means nothing..!
Too loose, too tight, barrel shaped, tulip shaped, too rough...again, please explain your informative wording.
Mike
Old 07-16-2018, 08:08 AM
downshift1's Avatar
downshift1
Too loose and and very inconsistent.
