JCW NM Engineering Power Module
#27
So I have a little confession. I could be a bit in the stubborn side sometimes and wanted to believe running NM on high with 91 octane yields better result that it would running it in low with the same fuel. I must say that running 100 octane on high is a beast. I fill up the tank about once or twice a month with 100 octane but mostly run on 91.
Setting it on low today, it just felt more responsive and the power felt more stable and gradual. Running it on high, it almost feels like a slight lag but the torque and power is there. In conclusion, I'm keeping it on low until I put race fuel.
Warning (all measurements are done with a highly calibrated butt dyno. Accuracy may be differ from person to person. It's accurate to me and my car only)
#28
I also run mine on high all the time. I use Lucas Oil Octane Boost and it works just fine.
#30
Any MMT based octane booster would work. Non MMT based wouldn't do much to increase octane.
Pull your plug or cat after a few bottles and if it's MMT based it will be reddish orange color. Or check their MSDS for MMT. I wouldn't use octane booster too often, it can't be good for your emission system. No matter what the manufacturer say...
RP, Lucas, LiquiMoly, Torco are all legit octane booster with MMT.
My cat after 3 bottles of LiquiMoly MMT based octane booster.
#32
Those new F56 S and JCW cats are so big. Saw one in person and nice you can actually see them now with the new set up.
#34
I tried it, and it does run stronger, but inconsistently for me. I don't think the ECU was happy. Some days my car seemed to have a lot more power, next time seemed to lose power. Running race fuel from the track made it perfect all the time, just expensive. On low setting, power seems great to me and I don't think too much stress on the tranny.
#35
NM module on high setting with race fuel (101 octane) is great. The question is how much can you get out of it as you transition to premium gas (91 octane) it's definitely noticeable, almost sluggish. Most people have switcheded back to low once race fuel isn't being used. Still good, just not as fun. You gotta pay to play I guess.
#36
I would rather run an Aquamist HFS-4 h2O/meth injection. Does anyone know where the nozzle can be mounted?
#37
Generally, I do the same and try to transition going from 101 back to 91. If only we can get a consistent 93 on most station, I would take that route. The race fuel is 7 miles away which isn't too bad, but not close enough to use as my go to station for their 94. If only the tank was as big as the gen 2. The extra 2-2.5 gallons would sure can come in handy at times.
#38
The only reasonably close unleaded 100 octane (Sunoco)is 70 miles away and costs $9 per gallon, therefore, it is not a choice other than special occasions. I do plan to get some and bring it here and have it on hand for a dynomometer run to determine how much additional power it will produce in the mini. I use 93 Octane Shell for the most part as it is readily available and reasonably priced. I use a Shell card and the rewards card and that reduces the premium by 10 cents per gallon.
#39
Has anyone encountered an inconsistency in the car's performance with the NM module? I have installed it on my stock JCW and it seems in 2nd and 3rd gear sometimes the car will pull hard, other times the car will not throw me back and it'll growl but feel as if it's being held back. Setting is on low, running 91 or 93 octane.
#40
Occasionally, I have had it happen, but rarely. I have taken it off whenever I take it in for service and it seems to stabilize after that. I consistently run 93 octane and that may help, but I am not sure. Try it on high, I queried NM about it and they advised me it wouldn't hurt anything. I am trying to locate some 100 octane unleaded within a reasonable distance to see if that makes a difference and also considering some octane boost additive. I want to see what it does with that. I had it on a dynamometer and it consistently showed a 20-21 HP increase over stock. I notice a big change when in overboost.
#41
#42
#43
I've been running the NM power module on high for over 100 miles. I mixed 100 and 91 octane and am at 95 octane.
I noticed in normal mode I hit 21 psi and it sure pulls hard in the top end. However, in sport mode I have only seen 17-18 psi. Bottom end is strong but it really flattens out at 4500 rpm.
I ran the power module on low and noticed lower boost in sport mode as well.
I disconnected the power module and still notice lower boost in sport mode compared to normal mode.
07-19-2016 08:55 AM
07-19-2016 08:54 AM
VYPUR
29
05-06-2016 02:29 PM
KevinR
04-28-2016 12:54 PM
