JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
WTB: JCW air box vacuum line
Old 06-12-2015, 10:43 AM
madmike007's Avatar
madmike007
madmike007 is offline
Hey Guys,
Anyone have a JCW air box laying around they are willing to part out?
Just got my car back from the mechanic and it looks like they broke the vacuum line (#3, long skinny one) that goes into the JCW air box. See attachment.
I tried ordering through the dealer, but they don't sell that part separately.
Thanks in advance.
Michael
Attached Thumbnails WTB: JCW air box vacuum line-jcw-air-box.gif
Old 06-12-2015, 11:14 AM
madmike007's Avatar
madmike007
Good news! MINI does have the part. It was a little difficult to find, but Jason @ Classic MINI of Ohio came through as always! Thanks Jason!
Attached Thumbnails WTB: JCW air box vacuum line-jcw-air-box-2.gif
Nathanlloyd (11-12-2017)
Old 09-30-2015, 10:32 PM
Aerobrew9's Avatar
Aerobrew9
Aerobrew9 is offline
Similar question, was feeling adventurous and decided to check the air filter on my 05 JCW. I bought it a year ago from the second owner and have about 50 k miles on it now. Removing the air box was more involved than I had expected from watching some of the R53 S videos. As I was re-assembling the box, the line that comes out the front of the box (toward the grille) dropped into the engine compartment. I managed to fish it out, however, it is now attached to...nothing. I let it idle for about 15 minutes and aside from more of a whistle than I usually hear, nothing seemed wrong. My question is, where does the end of the line connect to? I can't make out any likely disconnected lines which doesn't surprise me. What are the consequences and what does the line connect to? Any advice would be appreciated.
Old 10-01-2015, 06:40 AM
Aerobrew9's Avatar
Aerobrew9
Found it, bypass valve line.
Old 10-01-2015, 08:10 AM
madmike007's Avatar
madmike007
You are correct. It connects to the 'T' to the bypass valve.
Old 11-12-2017, 10:03 AM
Nathanlloyd's Avatar
Nathanlloyd
Nathanlloyd is offline
Help, don't know what type of plug this is.
Hey man, was just changing my air filter on my 2006 mini Cooper s jcw and number 25 and_or 26, the plug that is that connects too the air box had snapped. I have looked around and Cant find the name of the plug, but I need to Get one since the check engine light and also the supercharger doesn't kick in. I think it' opens a valve for the superchelargers boost or something, but don' quote me on that. All i know is that there is a flap that opens and that plugs into it. My best guess is that. But since it' is a rare version of that generation not sure how hard it' gonna be to get one. Hopefully it' the same across the Cooper Cooper s and Cooper s jcw. Thanks man.
Nathan
Old 11-21-2017, 07:30 AM
Derek86's Avatar
Derek86
Derek86 is offline
Does this line actually do anything? Mine was broken when I bought the car, I just capped off the line to the engine to prevent a vacuum leak, hasn't seemed to make a difference.
Old 11-21-2017, 07:33 PM
Nathanlloyd
Response
ya idk either. I have a jcw and on the back of he box there is a flap that is connected too that wire. Now if that wire controls that I don' have a clue. And just like you mine came broken. I guess when I moved it it finished it off, or I just hadent noticed before. A check engine light comes on for me but goes off after like 20 seconds of idle. Not sure. Took it too mini and they did an obd2 check and saw nothing. This been after the connection loss I found. For now I have just left it. One more question. Have you had any problems with your trans or diff... Do you have a 6spd manual jcw??. My trans wines and diff squeaks when turning. Possibly a lube problem but seems too common.
Old 11-22-2017, 03:13 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Whine not Walnuts is offline
The JCW airbox is set up so the flap at the back only opens at a particular RPM, thinking 4000. It is for car noise mandates. I not only disconnected the vacuum hose (plugged it off) but also removed all of the parts within the box. There is an electrical plug that goes through the plastic wall into the fire wall area.
When did you have the differential oil changed last? Also, if you are getting noises while turning it could be either a driveshaft or a wheel bearing.
Old 11-24-2017, 10:01 PM
Subw00er's Avatar
Subw00er
Subw00er is offline
The open tube... just plug it and your cel may go off. When new it went to a sealed diaphragm that moves a flap as mentioned.
Old 08-19-2018, 09:17 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
Oldboy Speedwell is offline
Just had my airbox out for the first time yesterday and noticed that the thin brittle vacuum line (16) is broken, traced it back to the BPV and plugged the line.
It didn't seem like there was a vacuum leak and I would have never guessed as idle was stable ---
how do these cars respond to vacuum leaks?
What are the identifiable symptoms?
I'm thinking of doing what WnW did and remove all associated flapper hardware.
The previous owner was good and had a nice Amsoil filter in there.
He had also let me know that he had de-flapped the airbox, but I noticed that there was a round opening and it had a blockplate in it,
#19 in the diagram:
WTB: JCW air box vacuum line-m29inrx.jpg
Dealer lists it as a "Sound flap" - 13717558249 - and it sells for $59.97!
I'll probably remove it as well, but I didn't know its purpose yesterday so I left it there.
Old 08-19-2018, 09:47 AM
OCR's Avatar
OCR
OCR is offline
Oldboy -
You don't need to take "all associated flapper hardware" off/apart.
All you have to do is remove the butterfly (flapper !). Simple, takes about 5 minutes after you remove the airbox lid.
Leave everything else connected. That way, the cars electronics, "think" everything is working properly.
Mike
madcanvis (10-05-2021)
07-16-2020 12:54 PM
silence2-38554
98
09-21-2016 02:52 PM
Zettinger
08-25-2015 04:04 PM
Lt. Dan
08-10-2015 12:46 PM
M7Speed
08-06-2015 01:48 PM
Quick Reply: WTB: JCW air box vacuum line
