Problems with the JCW air box
I ran into a couple of problems with changing the air filter in my '08 JCW Cabrio.
First, the tabs on the back of the back of the air box are broken - don't know if I did it or if one was already like that. How soon does that need to be fixed?
Second, I cannot for the life of me get the clip over the front air hose (one going from the box to the engine). Is there a trick to it?
Tony
Tony
Without a tight seal in the back, just run the risk of unfiltered debris in over the top of the air filter seal and directly thru the intake.....
Is it the tabs for the bottom or top shell cover ?
When I had that box, I used needle nose pliers for that clamp. Just have to be careful not to get pinched by the jaws in the process. There is a special tool for those as well, most auto stores carry them.
Hope yours doesn't melt. don't they recommend a turbo heat shield? I'd look at Way's turbo wrap instead of their shield.
There is no a separate part number for the top lid.
Here is the smaller kit that just has the box with the rear partition and the electronic part: Part # 13720395132 #2 kit. So its a little less then the full kits.
http://www.ecstuning.com/Search/SiteSearch/13720395132/
Vs the bigger kit for new installs.
John Cooper Works Intake Kit Part # 13720391513
http://www.ecstuning.com/Search/SiteSearch/13720391513/
07-16-2020 12:54 PM
08-12-2015 01:24 PM
M7Speed
08-06-2015 01:48 PM
