JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW are factory N14 pistons forged or not?
Old 09-27-2013, 01:19 AM
Trekzx's Avatar
Trekzx
Trekzx is offline
I've red all threads about pistons here, used "search" button many times. But the question is still actual:
is piston # 11257576973 forged?
where can I find some document that proves that it is forged or cast?
Old 09-27-2013, 05:13 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
Does anyone know the alloy used?
Old 10-22-2013, 02:43 PM
bigcooper666's Avatar
bigcooper666
bigcooper666 is offline
Yes
i found that out contacting my local mini dealer
bigcooper666
Happy motoring
Old 03-08-2017, 02:07 AM
Frederick Reckeweg's Avatar
Frederick Reckeweg
Frederick Reckeweg is offline
Be useful and write the answer SMH
Old 08-09-2017, 04:58 PM
Sstrickstein's Avatar
Sstrickstein
Sstrickstein is offline
MCS are cast, JCW are forged with lower compression.
thebestbear (03-16-2020)
Old 08-09-2017, 05:13 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
Can you provide documentation that they are forged? I've just never seen it. And people swap out the stock pistons with forged ones from CP, Mahle, etc, so if they are already forged why do this?
Old 08-09-2017, 05:20 PM
Sstrickstein
From
This forum and experts I talked to prior to my engine rebuild the factory built JCW had forged pistons. The MCS was Mahle cast. They are a harder piston material but more prone to cracking. I went with CP because I had a dead hole already. The CP set were less than Mahle and I didn't want to mortgage my house to buy a real JCW set
Old 08-20-2017, 09:58 PM
Tigger2011's Avatar
Tigger2011
Tigger2011 is offline
Alliance Member
Both MCS and JCW are pressure forged pistons. A true cast piston would not survive for long in a turbo application where the effective compression ratio exceeds 15:1. Both are made by Mahle using the same M142 alloy. The difference is in material thickness. Even CP are pressure forged just with more material, a more durable alloy and a better design IMHO. An actual full billet forged piston would be cost prohibitive.
rtk90
08-29-2019 09:08 AM
embiggenedmini
10-15-2015 12:36 PM
molala
10-02-2015 01:53 PM
09-04-2015 11:43 AM
squawSkiBum
09-02-2015 09:56 PM
Quick Reply: JCW are factory N14 pistons forged or not?
