JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW New Down Pipe and JCW stock exhaust or DP and Full exhaust?
Old Apr 26, 2012 | 07:37 PM
arnk0006's Avatar
arnk0006
Hello all,
I have some questions about what to do with the exhaust on my Mini JCW 2010
What size is the pipes on the stock setup 2.5"?
I am in debate on keeping stock setup except for new cast manifold from Way and new Down pipe.
Then I was looking at a NM full DP back exhaust setup.
What do you all have on your rides and what do you suggest.
I don't mind the current exhaust and sound but I would like to increase the HP and also allow my ALTA tune to safely do Tune Stage 2 and possibly 3 on occasion.
Can I get away with manifold and DP or should I just swap every thing out?
Trying to avoid drone as well.
Let me know your thoughts.
Old May 1, 2012 | 03:19 AM
ENGINE 58's Avatar
ENGINE 58
just downpipe it with the jcw exhaust. i dont think the mani is gonna help much on a factory jcw. maybe on a mcs it would.
Old May 1, 2012 | 09:11 AM
sspreso11's Avatar
sspreso11
I've been thinking about a similar setup myself, i.e. just doing a cat less DP with resonatorless stock JCW exhaust. It would be a catless system at that point so if it is indeed 2.5" we should be good to go.
Old May 1, 2012 | 09:20 AM
arnk0006's Avatar
arnk0006
I was looking at the Akrapovic 100 cell DP and JCW exhaust stock. May goto NM later
Old May 1, 2012 | 09:24 AM
2009R56JCW's Avatar
2009R56JCW
Akrapovic downpipe with the stock jcw manifold that has been port matched to turbo and head
then extrude honed with a ceramic coating inside and out will give very good gains.
Keep the stock Jcw exhaust but replace pipe from downpipe to resonator to get rid of the slight pinch
the stock system has just after downpipe.
Old May 1, 2012 | 09:29 AM
2009R56JCW's Avatar
2009R56JCW
Will be very loud and every cop you see will pull you over for db noise.
2009R56JCW's Avatar
2009R56JCW
Same manifold as Cooper S.
Old May 1, 2012 | 10:53 AM
sspreso11's Avatar
sspreso11
FYI, measured the resonator that was cut out and it is 2.25". So I don't think it would be enough to run a Stage 3 tune on the AP.
Old May 1, 2012 | 10:59 AM
arnk0006's Avatar
arnk0006
Would nm turbo back with do be able to run stage 3 alta tune?
Old May 1, 2012 | 11:00 AM
sspreso11's Avatar
sspreso11
Nah, there are a enough rednecks with straight pipes on their trucks that you won't even hear my car. After measuring the JCW to be 2.25" I will just do the full turbo back when it comes time to tune up to the stage 3 level.
Old May 1, 2012 | 11:51 AM
2009R56JCW's Avatar
2009R56JCW
Rednecks on harleys and in trucks get away with it because most of them are on a first name basis with the cops or related.
Old May 1, 2012 | 03:10 PM
arnk0006's Avatar
arnk0006
As far as downpipes. Would the akrapovic 100 cell suffice or just go with a less expensive WMW Catless DP? Just curious. I don't want to have a lot of drone in the cabin if any. Just performance .
-2009R56JCW : Where did you buy your internals from?
W
Old May 1, 2012 | 03:12 PM
2009R56JCW's Avatar
2009R56JCW
If you go with a akrapovic keep your resonater.
cp/carrillo for rods and pistons
Old May 1, 2012 | 10:44 PM
turtle343's Avatar
turtle343
i have a riss racing catted ceramic DP and it is awesome with the stock JCW set up. sounds stock until you floor it. it also pops and bangs on every shift which i love. i have no problems with my RMW tune and it.
Old May 2, 2012 | 12:03 AM
Miykl's Avatar
Miykl
Cat less RR DP and stock JCW exhaust. No drone. I would not ditch the resonator. Stage 2 Alta tune cleaned up the sound nicely.
Old May 2, 2012 | 05:16 AM
ThePenl's Avatar
ThePenl
No, it's not...
Have a read at the following please:
http://www.minitorque.com/forum/f13/...tml#post445923
Old May 2, 2012 | 05:18 AM
ThePenl's Avatar
ThePenl
For exhaust info, please read the following:
http://www.minitorque.com/forum/f272...tml#post447827
Old May 2, 2012 | 06:35 AM
TazMinianDevil's Avatar
TazMinianDevil
So it starts out 2.5 and then tapers down to 2ish. No wonder there wasn't a confirmed size ever posted. I didn't think to measure both ends of the resonator.
Old May 2, 2012 | 07:36 AM
Ronin5729's Avatar
Ronin5729
Peep these videos...
http://www.youtube.com/playlist?list...F&feature=plcp
'09 JCW Clubbie with stock exhaust and Riss Racing ceramic coated/catless downpipe.
Any louder than that and it won't be fun anymore...
Old May 9, 2012 | 12:47 PM
BoostMe's Avatar
BoostMe
Really like your thinking here, don't see as much use of extrude honing, a true performance treatment that improves flow without sacrificing velocity.
Old May 9, 2012 | 12:59 PM
2009R56JCW's Avatar
2009R56JCW
Yeah most people on nam think roof racks ,intakes and stickers make power.
Old May 9, 2012 | 09:01 PM
TerminalVelocity's Avatar
TerminalVelocity
It's a known fact that roof racks completely negate torque steer gosh darnit!! lol
Old May 9, 2012 | 10:16 PM
BoostMe's Avatar
BoostMe
now that's where the paycheck meets speed, I knew I needed those things, man that certified tuning stuff is for the byrds, stickers and that new cold intake on dry ice is where it's at!!!
now that's entertainment!!
Old May 11, 2012 | 09:29 AM
TerminalVelocity
And stereo's?
Old May 15, 2012 | 10:14 PM
Marioalex24's Avatar
Marioalex24
Sweet.
