Best Size Goodyear Gatorback Belt for 2003 JCW
I am about to replace my A/C Compressor and will be replacing the drive belt at that time for the first time in my ownership. The JCW has an 11.3% reduction pulley and calls for a 6PK 1374 belt.
I want to put in a Goodyear Gatorback belt and there are two lengths I can go with as they don't have one that matches the factory 1374mm length.
Gatorback 4060537=53.74"/1365mm
Gatorback 4060539=54"/1371.6mm
I know most on here use the 4060537 for the bigger aftermarket reduction pulleys. Would the 4060537 be to short and put to much tightness on the tensioner and pulleys? I thought if it would not be too short it would give me some extra length and belt life as the belt stretches over time gradually getting to 1374mm.
Is any one using this shorter belt on their JCW or should I use the 4060539 to more closely match the factory size belt? I would appreciate learning from others experience here.
Thanks for any input.
07-16-2020 12:54 PM
08-07-2015 09:51 AM
08-07-2015 08:10 AM
