JCW 2011 Jcw Engine Bay -no Label?
here is my 2011 MINI JCW engine bay, but there is no any JCW labels in or i cant find one. Does it true, i mean i read a threat says the distribution center could reserve the report if the car was damaged on the road of transition and did not over 10% (20%?) of total value. i may too over but...erm... Thank you.
Only a minor addition to your question - SC law requires no reporting out of damage less than 10% of the vehicle value, which is where every single Mini ships through. If it happened at the dealer in your state, there should be a repair note listed under the VIN.
No sticker or label on the engine of a Factory JCW.
You can tell by the Vin # if you have a true factory JCW. The vin should have MF93 in it (Mine does) also I think the fifth # from the right or could be left is a 9.
The only other way is to step on the gas.
The Factory JCW engine & Transmission is put together in Germany using a different block and different beefed up internal components as well as different gears then the S or justa.
I guess the Germans don't like stickers etc.
******************As you can see, Engine and tranny from Germany.*****************************
Kimolaoha
Jul 5, 2023 01:04 PM
R50/53 Respray - Color Change?
chicohuahua
22
Aug 20, 2015 11:17 AM
