JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW What's the safe maximum turbo boost psi in the JCW Stage I engine tuning kit's ECU?
Old Dec 30, 2007 | 02:35 PM
BobinPhilly's Avatar
BobinPhilly
If anyone knows the psi level at which that ECU will shut off fuel to protect the engine, please let us know.
Old Dec 31, 2007 | 05:19 AM
a96bimmerm3's Avatar
a96bimmerm3
Shutting off fuel= BAD. The ecu has control over boost through the wastegate and the dv, so you should be safe. Why do you ask?
Old Dec 31, 2007 | 05:22 AM
JCWGrover's Avatar
JCWGrover
shutting off fuel on a boosted engine, not pretty
Old Dec 31, 2007 | 08:05 AM
BobinPhilly
Trying to decide if it's worth getting an auxiliary boost gauge, presumably to be able to monitor normal boost psi (wonder what that is?) and to make sure I don't exceed safe maximum (over)boost at high rpms (which is what I'm trying to find out). Otherwise, what are the benefits of such a gauge (other than that it looks neat!!)?
Old Dec 31, 2007 | 12:39 PM
msh441's Avatar
msh441
I have no link to back it up right now (sorry), but I remember hearing that the stock car worked at around 10 psi, with 14psi being the overboost. I don't believe the JCW ECU is altering the boost too much (maybe 1-2 psi). More reprogramming the fuel/air mix & ignition timinig. If I find the link to back that up, I'll update my post.
Alta's GT Turbo has upped the boost a bit and works at around 14-17 psi. There may be some details you're looking for in that thread: https://www.northamericanmotoring.co...d.php?t=121411
Ambient Thermal Management
Aug 7, 2015 12:27 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
