JCW JCW Challenge Stripes?
Does aesthetic creations make a stripe kit similar to the new JCW challenge cars? The closest I could see is the viper kit but they're spaced farther apart than the JCW ones.
I don't know what the JCW Challenge cars looked like but someone in another thread had commented that the stripes in my signature looked like Challenge stripes. If so, you can check out my gallery for more pics.
These stripes were done at the dealer by their local guy for $240 total.
The stripe would be quite simple to replicate by any of the vendors...Challenge MINIs have been running these stripes for a long time. IMO, the best graphics in the world (literally) were found on the Challenge MINIs...I always found the John Cooper Challenge (and now MINI Challenge) galleries fascinating.
T-Horn - yours are almost exactly how I want mine. I would prefer them to be slightly thinner (about the total width of a US spec plate) but if that's not readily available, the style you have would make me very happy. Can you PM me the info regarding your stripes?
Here's what the current Challenge car looks like:
They're almost identical to T-Horns, except for a bit of a difference in the back.
I'm sure if you emailed Mike at AC he could relatively easily hook you up w/ some stripes that look like the ones on the Challenge car. I've been looking for the exact same thing (I think I'm the one who was lusting after T-Horn's stripes earlier.) and I haven't found anyone who's got an exact match in their regular stock.
Mini Pirate offer a full set of Challenge car graphics on their site, but they look to be an older design (the stripes look like standard Mini bonnet stripes).
The closest thing I've found are the Sport Stripes in the Mini accessories book, but they don't cover the lower sections (bumper, spoiler) however I imagine it'd be somewhat trivial to use some bits from a second set to do the full look.
anyone knows the part # for these? minipirate sells them for $130; wondering how much they are at the dealer or morristown
If you need actual part numbers I could dig up the ones you want, but that should be enough to go on.
Looks great! Change the color to Chili Red and slap on some Bridge-Spokes and that's my car.
Are your front turn indicator lenses still yellow, or is that just from the bulb?
Thanks for the compliments!
heres one more pic
I might be forced to do that as well; that's pretty noticeable from the front, not so much from the rear. Too bad the stealth bulbs are so spendy unless you just do the 'spray the OEM bulb w/ silver paint' trick. Sylvania has some replacements in their Silvervision lineup that're only ~$12 for a pair, but the downside to those is that they look slightly blueish when not lit. (That might actually be an asset with your LB car.)
They're the 'Sport Stripes' and they're $85 per kit (available for the body [boot, bonnet] or roof). They come in red, white, or black. If you want to do the challenge look you'd actually need three kits - one for the roof, one for the bonnet/boot, and one to cover the bumper areas the body kit doesn't cover.
hmmm maybe i should get those then... my only problem is... i was looking at the headlight today and i have no clue how to get to that light bulb...
That's something that I would think should be in the user manual, or if it's not then someone'll have a how-to posted on here.
Hey guys.....check out this place http://www.signsupply.com/Vinyl/FDC/2100.asp
you can buy stripes in about any size and color for about $40 for the whole car...this is very high quality vinyl, FDC 2100 or 3m Scotchcal....this is the same or better than most graphic automotive stripes and a lot cheaper! cheers!
In the wheel well liner, you'll see two removable plastic covers. One of those will let you access that turn signal bulb.
if i had seen this before i probbly would have went this route as i had to custom cut out the area around my emblems anyway. For those considering diy for the stripes, definitely buy this setup.
bctf1
Aug 6, 2015 12:55 PM
