Interior/Exterior R56 roof rack
Old Aug 9, 2012 | 05:49 AM
  #351
DixonL2's Avatar
DixonL2
I've had great luck with these guys: http://www.orsracksdirect.com/
AND, importantly, email or IM them with questions and discount coupons seem to appear...
Old Aug 9, 2012 | 05:52 AM
  #352
kmwatersaz's Avatar
kmwatersaz
Carrier Sources
Thanks a bunch. Grew up in Pittsburgh but haven't seen it in 50 years. They say it is quite different now. Stay well.
Old Aug 10, 2012 | 07:25 AM
  #353
corliss hale's Avatar
corliss hale
I just installed a 2nd hand factory rack, and got to say, the washer trick is absolutely essential - it not just keeps the feet from sproinging out repeatedly, but by holding things together more securely makes everything go together much faster. I'd been fussing with the rack for about 45 minutes, unable to get any of the feet to engage when I decided to try the washer on one of the towers, did so and it went right in, as did all the others when I added the washer. In addition to keeping the feet from snapping out, it seems to hold them flat more securely so the go in more evenly.
Oh, I also recommend not trying to cut the rubber unless you can REALLY CLEARLY see the cut lines - otherwise its just too easy to cut short, and the extra rubber will make it hard to get the feet in the slot, possibly requiring extra trimming and making more of a mess than if you just tore it along the dotted line as directly. Take the tweezers and tug, as directed, if you have faith it will break where it is supposed to (actually, long before it snaps you can see the row of holes elongate which gives visual confirmation that it is going to break in the right place). You can always clean up with an Exacto later.
Oh, am I the only one worried that moisture will get trapped in the pockets and rot out the roof?
Old Aug 10, 2012 | 08:10 AM
  #354
cdtscout's Avatar
cdtscout
With the help of my son (I recommend a helper for the 1st install)...I installed my new roof rack on my 2011 MCS. I read the instructions and the information available on this forum in advance of installation...I would recommend this too.
I loosened up all the appropriate nuts and screws and gently "wiggled" everything in place then tightened everything down. The roof rack seems very solid and after a test drive at highway speeds...no whistle, just a bit of wind noise. With a sunroof, I don't think a bit of noise can be avoided at highway speeds.
This was not a complex job if you just exercise your patience and don't force anything into place. From start to finish I think we spent about 40 minutes....but, we were very careful and checked everything more than twice before the final tightening of everything.
My only concern post install is water seepage or leakage around the rain-gutter in the location of the cut-outs. That being said, I don't see anyone having a problem with this and I was sure to only cut out the material marked with the dotted cut-out lines.
Next-Up: Install the Cargo Box as we prepare for a significant Father-Son Road-Trip!
Old Aug 10, 2012 | 08:53 AM
  #355
DixonL2's Avatar
DixonL2
It's really great now. Economy's back, really active Mini club, LOTS of local and regional events, and now THREE decent sports teams (The Penguins, some baseball team, and some other football team).
...if you just exercise your patience and don't force anything into place...
EXCELLENT words of advice! How many of us have broken stuff using the "larger hammer" technique? ESPECIALLY with roof racks, whether you have the gutter style or the "pads on the roof" style, it only takes one screw-up and you're looking at a dent (or worse) every time you get in the car. That's one of the reasons I went with a hitch and hitch-mount carrier for either bikes or gear.
...a significant Father-Son Road-Trip!...
My son's 19. We took a Significant Father Son Road Trip when he was 9 that we STILL talk about. We've taken many since. Take as many of these as you can.
(OK, back on topic now!)
Old Aug 10, 2012 | 10:34 AM
  #356
absoluteczech's Avatar
absoluteczech
Originally Posted by BMC_Kid
It took me about 45 minutes to first install the OEM rack. That is mainly taking the time to cut the plastic rain gutter. Once that was done at all four locations it tool me maybe 10 minutes to actually install the rack.
Now, once that has been done, it takes me about 5 minutes to take the rack off and maybe 10 minutes to reinstall it.
Really, it is very easy to install and remove once you've done it a few times. As far as what it looks like without the rack installed after the gutters have been cut, you really can't tell it at all from 3 feet away. Up close, the plugs that come with the kit push into the slots very tightly and are almost invisible. You wouldn't know it unless you were told they were there.
thanks for the reply. would you be able to show me a picture on your car what it looks like w/out the plug and with the plug installed? thanks
Old Aug 13, 2012 | 07:49 PM
  #357
absoluteczech
bump for anyone that has a photo of what it looks like w/o the plug
Old Aug 14, 2012 | 01:36 AM
  #358
BMC_Kid's Avatar
BMC_Kid
Sorry, been traveling. Will be out of the country probably until late December.
Old Aug 14, 2012 | 08:02 AM
  #359
absoluteczech
eek! no worries thanks for the reply
i just received all my yakima stuff, if this doesnt work well, its all going back and i'll just order the oem base bars
Old Oct 29, 2012 | 04:26 PM
  #360
BJM's Avatar
BJM
So I have had my MINI a few days now. I do a lot of kayaking during the summer so it was a no brainier to get the factory roof rack along with it. As soon as I hit 62mph, I notice a low volume/high pitch whistling noise. I assume it to be the roof rack. My friend's Subaru does something similar, as well and my other friend's VW. Is there a simple fix?
Old Oct 29, 2012 | 04:35 PM
  #361
Eddie07S's Avatar
Eddie07S
My bars came with rubber strips that fit the slots in the bars. Makes no noise at all. Does yours have those in place?
Old Oct 29, 2012 | 04:45 PM
  #362
BJM's Avatar
BJM
I'm not sure honestly. I got a kit with all the mounting/un-mounting hardware... There are several rubber strips in there. Maybe that's what you're talking about. Where do they go? Does yours whistle if you take them out?
Old Nov 6, 2012 | 06:05 PM
  #363
Eddie07S's Avatar
Eddie07S
The rubber strips would be what you are looking for. You lift the lock plate on one side like you are going to take the racks off the car and they slide into the slot when you don't have something like a bike rack attached. I have no whistle.
Old Nov 8, 2012 | 05:50 PM
  #364
Mini///M's Avatar
Mini///M
What Baskets are people using? I love the Luggage Basket from MINI but its so expensive.
Old Nov 19, 2012 | 06:34 PM
  #365
mcbray's Avatar
mcbray
Any tips for removing the OEM base support system? I had the dealer install one as part of my new mini purchase but I'd like to remove during the winter months. I tried loosening the brass nut but I can't get the feet to free from the car.
Old Nov 22, 2012 | 02:11 PM
  #366
Rgoodwin's Avatar
Rgoodwin
Loosen the hex nuts under the bars.
Old Nov 23, 2012 | 06:52 AM
  #367
Eddie07S's Avatar
Eddie07S
I wiggle it and "encourage" the feet to move inward with a screwdriver. I have also removed the stops so I can take the nuts off.
Old Jan 17, 2013 | 06:01 PM
  #368
walk0080's Avatar
walk0080
Old Jan 17, 2013 | 07:25 PM
  #369
fupac133's Avatar
fupac133
I have the wheel on from thule and i am still able to open the sunroof.
Originally Posted by walk0080
Ryoma111: Great looking setup.
Do you find the Thule Wheel-On holders get in the way of the sun roof panel when open? Seems like the bracket design underneath would be very close.
I am thinking of a rockymounts aero and Thule wheel-on for my mini roof rails.
Old Jan 17, 2013 | 07:41 PM
  #370
walk0080's Avatar
walk0080
Old Jan 22, 2013 | 12:42 PM
  #371
pasha.mostaghim's Avatar
pasha.mostaghim
Originally Posted by Flyinace2000
Mine whistled a lot when the ski holder was empty but not when i had skis in them. Now that i am done skiing for the season i took off the ski holders and put in the rubber strips. No whistling at all. Very quiet with no attachments.
Flyinace2000,
Did you end up finding a solution? I have the same setup as you do, and clearly won't drag my skis around for for the sake of preventing the whistling. I'm going crazy with this whistling business...thoughts?
Thanks,
Pasha
Old Jan 22, 2013 | 01:19 PM
  #372
MikewithaMini's Avatar
MikewithaMini
I have the base only on my R56 with sunroof. I took off the 3 little plastic wings to wrap my cross bars and never put them back on. Noisey as all get heck. Looking at Yakima pages, it looks like they have some attachments that allow OEM cross bars to adapt to any Yakima product, thinking fairing. Going to the bike shop later. Also, looking at the Thule pages, their rubber strip is grooved with the purpose of directing air for less noise as well. My son has Thule Aeroblades and is measuring the slot for me today. I haven't put my Rockymounts tray on yet.
Old Jan 22, 2013 | 05:49 PM
  #373
Eddie07S's Avatar
Eddie07S
Originally Posted by pasha.mostaghim
Flyinace2000,
Thanks,
Pasha
I have a clamp on ski rack that works great.
http://www.prolineracks.com/mont-bla...ski-racks.html
Takes 5 minutes to put on or take off, so I don't run with it on all the time. Most of the time, I just put the skis in the car when I am going by myself.
Old Feb 6, 2013 | 06:32 PM
  #374
Dillon's Avatar
Dillon
Factory base rack took about an hour to install, Thule sidearm another 45 minutes
Old Mar 22, 2013 | 05:08 AM
  #375
StPeteAPB's Avatar
StPeteAPB
First off, thanks for a great thread. Lots of good info here.
I wanted to mention a great How-To in case anyone had a hard time making heads or tails from some of the instruction manual's details ... I did! Here's the how-to:
http://turn17.com/?p=261
Secondly, for everyone who has installed their roof racks - how many of you take them off when you're not using them? I want to make sure that the four "sealing caps" in the MINI Roof Rack Kit suffice for plugging the slots well so there's no water leakage into the roof.
Thanks again!
Alan
