Interior/Exterior Aero Grill, alot tougher to install then I thought.
Old Jul 12, 2006 | 07:08 AM
  #26
SSMini's Avatar
SSMini
Here are a couple pics before and after the grill install.
Attached Thumbnails Aero Grill, alot tougher to install then I thought.-mini-before-face-lift.jpg   Aero Grill, alot tougher to install then I thought.-mini-after-face-lift-2.jpg
Old Jul 12, 2006 | 04:36 PM
  #27
Smokey's Avatar
Smokey
Looks good - It really works well with that color
Psst: might want to think about some real ramps though
Old Jul 12, 2006 | 05:44 PM
  #28
SSMini's Avatar
SSMini
Yea, My back yard ramps there. My REAL ramps are being used on my other project. I was toooo lazy to drive 10 miles to borrow my Dads ramps.
Old Jul 22, 2006 | 10:03 AM
  #29
miniprof's Avatar
miniprof
We installed our aero grille yesterday and it went really well. Used a socket to get the nuts most of the way off, then screw driver and pliers for the last little bit. As mentioned elsewhere, loading the socket with nuts helps reinstallation.
On the lower portion, we did things a bit differently. Our dremel was acting strange, so we used a coping saw to cut down the grill. We taped a line where we wanted to cut it. Then we cut vertically next to each tab down to the desired depth of the cut. Then we angled the blade next to one tab, then cut horizontally to the next tab. We then switched the blade around and cut out the little angled pieces of plastic that were left. It took about 20 minutes to do the whole thing and there was no burning plastic to deal with!
The sticky tape was a bit of a mess, but not horrible. We didn't clean it off as well as we probably should have, as we covered that portion with black vinyl tape and now you can't see it at all anyway.
The total job took us about three hours and was well worth the effort.
W0TM8
Dec 19, 2019 07:50 AM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
