Interior LED's
Anybody know the wave length of the stock orange LED interior lights - want to add one or 2 and want them to match.
Thanks Joey |
Orange LEDs
1 Attachment(s)
Joey -
After going thru the same "what's the wave length" exercise you're on, I found some orange LEDs on CarDomain.com in the right color with the diode already atttached. Made for a quick install and I have them switched using Ian Cull's (GBMini) custom circuit, which make the rear fog toggle function as an auxilliary switch. This set up works great to give night-vision-friendy interior lighting to find those dropped dimes after dark. Good luck with your mod! Bootmonkey |
Thanks a bunch for the info - fwiw I'm pretty sure the orange that matches is 605 NM as opposed to the longer one. Hopefull Ian is still making the circuts.
Thanks again. Joey |
Got any more info about these lights?
1 Attachment(s)
Cool interior shot @ BootMonkey - made me remember another nice picture - see attached.
Tatt |
Originally Posted by Bootmonkey
Joey -
After going thru the same "what's the wave length" exercise you're on, I found some orange LEDs on CarDomain.com in the right color with the diode already atttached. Made for a quick install and I have them switched using Ian Cull's (GBMini) custom circuit, which make the rear fog toggle function as an auxilliary switch. This set up works great to give night-vision-friendy interior lighting to find those dropped dimes after dark. Good luck with your mod! Bootmonkey question did you change the LEDs on the tach and speedo as well? nice work! wow! Carlos |
| All times are GMT -7. The time now is 06:46 PM. |
