Interior/Exterior Gauge Mod???
Old Dec 23, 2004 | 08:52 AM
FlynHawaiian's Avatar
FlynHawaiian
Gauge Mod???
Can the Speedo and the RPM gauges be swapped on a car that has the crono pack? I am in the mits of ordering a new mini and would like the extra gauges, but would like them swapped over so I can see how fast I am going
Old Dec 23, 2004 | 09:53 AM
bigpmj's Avatar
bigpmj
Your tachometer and speedometer are above the steering wheel...do you think they'd sell a car without a speedometer?
Old Dec 23, 2004 | 09:58 AM
bigpmj's Avatar
bigpmj
Old Dec 23, 2004 | 11:15 AM
BrewSwapGuy's Avatar
BrewSwapGuy
Formerly PassatDoTd
Smartass. What he meant is that if you get the chrono pack you have the tach on the left and speedo on the right above the steering wheel. He wants to have the speedo on the left and the tach on the right above the steering wheel. This is the swap he is talking about.
I have no idea if this is possible.
Old Dec 23, 2004 | 12:12 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Since the inside of the tach/speedo assembly consists of a large circuit board which covers the entire inside area of the gauge shell and contains all the readouts, indicator LEDs and illumination LEDs, along with the gauge movements in their current positions, I would say that this is an impossible task unless someone wants to reengineer the entire assembly to lay out the pc board to accomodate the swapped gauges.
Now, if the car is ordered with the conventional gauge pack, one might be able to get creative and swap the positions of the tach and speedo by using Australian-spec instruments from MINI. Aussie cars come with the speedo on the steering column and a humongous tach in the dash which is flanked by the temp and fuel gauges. Something about Australian motor vehicle laws that requires the speedometer be in front of the driver.
Old Dec 23, 2004 | 01:28 PM
bigpmj's Avatar
bigpmj
So...he just wants to switch the locations of the tach and the speedo...? That doesnt make much sense to me.
Old Dec 23, 2004 | 01:42 PM
FlynHawaiian
Ok so the reason why I want to switch the two is because I lose the speed from 50~120 mph. I cannot see that part due to the steering wheel being in the way. The BMW E39's had the same problem with me. However, I could read the tach no problem. The tach is not really really necissary to me, typically you know when to shift. However, it would be nice to know how fast I am going :smile: . This may not make sence to some, but us long torso people know about this problem. So what to do? Eigther I don't get the crono package and leave the speedo in the middle, swap the speedo for the tach (like on the ausi cars) or simply switch the tach position with the speedo position. *shrugs* let me know what I should do :(
Old Dec 23, 2004 | 08:26 PM
bigpmj's Avatar
bigpmj
Ah, I see...you had me confused.
I'm 6'3, so the top portion of the tach is cut off for me, so I know just what you're talkin about.
In my opinion, I wouldnt get the chrono pack...but thats just me.
PsychoRallye
21
Feb 17, 2019 06:08 AM
dinomaniac
Sep 18, 2018 04:19 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
Oct 19, 2015 08:07 PM
jennster
Sep 28, 2015 06:19 PM
