Interior/Exterior Replace tail lights to Union Jack
Old 07-17-2019, 02:19 PM
Michael Bencosme's Avatar
Michael Bencosme
Michael Bencosme is offline
Hey, I know there is a thread on this forum about the UJ light and hiw to replace it and coding but I am not sure of this since on the thread was a little confusing with uk/us version and non-s/s/jcw so: I recently bought a new 2019 Mini Cooper 2 door non-s signature packg and want to make the change to the UJ tail lights, I’m thinking buying from WayMotorWorks (Here are the UJ Lights). Is it better to buy the US than UK version? (I live in GA, don’t know if there is any regulations on that), Will I need coding and/or other parts? Or it will be plug and play?
Please let me know how can I approach this mod.
My current lights are attached:
Summary:
2019 MINI Cooper Hardtop 2-Doors (F56)
Live in GA
Replace tail lights to Union Jack Tail Lights from WayMotorsWorks
US or UK Version?
Coding required?
Other parts?
Old 07-17-2019, 02:36 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Minnie.the.Moocher is offline
Why not let Way do the install?
The following 2 users liked this post by Minnie.the.Moocher:
bluonyx (07-17-2019), Clutch Wotan (07-22-2019)
Old 07-17-2019, 02:44 PM
Michael Bencosme
Send them an email and not available for the next three weeks for the service.
Ands they didn’t provided a quote but that will be some bucks that I can save and is not that hard to do the deassembly and assembly IF is just plug and play.
Old 07-17-2019, 07:40 PM
bluonyx's Avatar
bluonyx
bluonyx is offline
Minnie has a great point, let Way do the install on the lights. Mine was an 19' JCW with Union Jack lights already but I wanted to switch to the UK ones cause I liked the amber and it was an nightmare. Went back a forth for a month then I finally returned them. Just make sure you get actual OEM ones.
Old 07-21-2019, 11:47 AM
Andrew Park's Avatar
Andrew Park
Andrew Park is offline
I bought the OEM US version but coding is required. If you are unfamiliar with BMW/MINI coding I suggest you get it installed by someone who knows how since you can easily screw your car up.
Old 08-06-2020, 03:03 PM
Sansho's Avatar
Sansho
Sansho is offline
If you didn't do this already .... UK/Euro lights have amber turn signal, which is what I installed on my 2018 with LED lights. US lights have red turn signal. If you follow directions and discussion in this post, that provides what has to be done for the install and programming (most use BimmerCode). There are other discussion threads, however, I found that one sufficient.
If GA requires periodic inspections, you can look on the GA DOT web site to confirm what's required for turn signals. I think you'll find that both amber and red are acceptable.
Old 01-21-2021, 03:12 PM
MiniF54's Avatar
MiniF54
MiniF54 is offline
Cool
would you share where you got your OEM lights im trying to see whats available and so far i've seen only 1 on aliExpress
Old 01-21-2021, 04:14 PM
Sansho's Avatar
Sansho
Sansho is offline
You can order the US lights from a mini dealer. For example, the BMW Mini Part Store has them at $190 each ($288 list).
Edit: That's for F55/F56 tail lamps ... notice you have an F54? In that case, go to realoem.com to find the part numbers. I'm not familiar with which F54 has UJ lights.
Old 04-01-2021, 04:47 PM
Flamewinger's Avatar
Flamewinger
Flamewinger is offline
2016 F56 JCW Curious as I tried having the dealer install and after 3 days of playing with it they say they are unable to do it. I showed them a video on how to re-code and they are not allowed to do it.
I want to do it. I have a VGate BT 4.0 coming and Bimmercode app.
Is this all I need? I’m in the SF Bay Area and don’t know of anyone that has done it.
Old 04-02-2021, 08:59 AM
ghstrdr's Avatar
ghstrdr
ghstrdr is offline
Go to you tube and watch MINIVLOG's videos on the coding. Its straight forward and easy to do. And yes the adapter and bimmer code works.
Old 04-02-2021, 04:38 PM
Flamewinger
As mentioned, tried getting the dealer to do the install and they ere not able to work. These were OEM retro kit and they wouldn't light up for brakes or turn signals. Any recommendations on Union Jack lights that will work on a 2016 Hatch JCW?
I've seen some on Amazon but not sure about them.
asecret
F54 :: Clubman Talk (2015+)
150
04-14-2024 09:52 AM
Dmads
12-30-2021 07:55 AM
jpsjr1970
09-15-2020 10:39 AM
cantinoz
08-12-2020 02:06 PM
06-28-2019 12:03 PM
Quick Reply: Interior/Exterior Replace tail lights to Union Jack
