Interior/Exterior retrofit heated seats in '07 R56 base
Old Dec 27, 2017 | 01:03 PM
Totallyscrambled's Avatar
Totallyscrambled
Hi All, not sure if someone covered this yet, I have a 2007 base R56 and just got a donor car with heated seats and controls in it, I wanted to switch over to my car and was wondering if anyone has done this before, and what is involved coding, parts, ect.
Old Dec 28, 2017 | 06:26 AM
Some aftermarket solutions:
https://www.northamericanmotoring.co...ats-added.html
It was easy on the Gen 1 MINIs as there was a kit, on the Gen 2 MINI the system is more involved as there is a main harness to the seat, the toggle bank with the switches and the harness for that. I dont know anyone how has done the full factory thing. Other than this :
https://www.northamericanmotoring.co...w-clubman.html
Old Dec 28, 2017 | 08:47 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Moved you to the right sub-forum, do a search here and lots of threads will come up.
Old Dec 29, 2017 | 04:59 AM
MiniToBe's Avatar
MiniToBe
I havent tried it, but the obvious would be the seats, window/heated seats combo switch, and fuse box. I think the fuses/circuit will be missing from the original fuse box. if the donor is a turbo, then the fuse box wont work same if it was for N16 engine.
then you would need the wiring. check https://www.newtis.info/tisv2/a/en/ for wiring diagrams.
ti22fjc
Aug 11, 2022 01:31 PM
joylove
Electrical
15
Jan 3, 2019 07:43 AM
patsum
General Mini related Ads
Sep 29, 2013 04:06 PM
mp5999
Aug 26, 2013 06:20 PM
TwOMINIs
Jun 26, 2004 04:24 PM
