Interior/Exterior A new question about sport seat swap
I'm swapping the (effing TERRIBLE) seats in my R50 for some comfy, supportive aftermarket reclining sport seats. I've already fabbed the airbag resistor leads, BUT... What about occupancy sensors in an 02 R50? I want both driver and passenger front airbags to function in an impact which I understand can only happen if the car thinks an *** is planted in the respective seat. One post said there are three leads under the seat, one for airbag (yellow) and two for the belts. (And I'm fine with a chimex or fastening the passenger belt if necessary.) Is the second belt harness for an occupancy sensor, and if so, or not, do you simply leave the circuit open, install another resistor jumper, or what? Thanks again for a great resource.
There isn't an occupancy sensor on an 02. Those didn't show up until 05 and 06. I just replaced my seats with leather from a 2012. Use your seatbelt harness and the resistor in the airbag. Or if you use mini seats from a later year retrofit the plugs to match on the airbag and you will be fine.
No there is no sensor. It knows if you get buckled in as the seatbelt buckle is wired in. And there is an explosive charge in the buckle that tightens the belt if there is an accident. You will want to reuse the buckle off your stock seat and retrofit it on to the new seat. It is held on with one bolt.
Then why does the fasten seat belt light come on when a passenger gets in and doesn't buckle up? The system knows somehow, right? It might not have the PIA pressure sensor that the 05/06 cars got, but it has to know somehow, right? Thanks again for the response and for helping to figure this out.
Thanks again. I can't explain it, but when I have a passenger that doesn't fasten the belt the light comes on. I've argued with a friend over it who refuses to wear a seatbelt (what if the car catches on fire and I can't get out, what if I'm submerged in water and can't get out, etc. My good friend is an effing moron.) I would love to figure this out. My lovely wife, who always buckles up and is never an effing moron, is the primary occupant on my right and I really want to know her front airbag is functional.
Did you document the steps, or follow some published steps to retro fit into your 03? I have the same year, and while the seats are OK, the driver lower cushion is worse for wear. Considering leather form something newer, heard it CAN be done, but not found much to show how.
07-16-2020 12:54 PM
ebowling
90
08-04-2019 09:15 AM
Powershift
08-16-2015 05:14 PM
