Interior/Exterior DIY - OEM PDC retrofit
Old 06-10-2014, 06:58 AM
heiker's Avatar
heiker
heiker is offline
Lightbulb DIY - OEM PDC retrofit
Dear all,
I have successfully completed OEM PDC (Park Distance Control) retrofit. It was done in R60 Cooper with manual gearbox and BoostCD radio.
Hardware added:
- 4 sensors
- 4 sensors' holders (sticked to the rear bumper)
- OEM wiring set
- PDC control module
Coding:
- adding VO $507 to FRM and CAS
- defaulting all ECU modules (so they will learn the new HW added)
- Activating PDC using INPA
It took me 6 hours of work, however manual claims, that it should be possible in 2,5 hour.
I will upload the photos from retrofitting later as well I will try to scan the PDC retrofitting manual. If anybody have question about PDC retrofit in the meantime, post a reply or PM me.
Last edited by heiker; 06-10-2014 at 02:10 PM. Reason: explaining PDC abbreviation
Quarky42 (02-18-2023)
Old 06-10-2014, 10:47 AM
mikey_t's Avatar
mikey_t
mikey_t is offline
Ok, i'll bite. What is "PDC" ?
Old 06-10-2014, 10:58 AM
trentiles's Avatar
trentiles
trentiles is offline
Parking Distance Control
Old 06-10-2014, 02:17 PM
heiker's Avatar
heiker
heiker is offline
PDC wiring
Here is the wiring:
- outside along the bumper support to the grommet on the left wheel arch
- inside from the PDC module across the trunk
- along the right footwell to the SPEG
Attached Thumbnails DIY - OEM PDC retrofit-01-wp_20140607_001.jpg   DIY - OEM PDC retrofit-05-wp_20140607_007.jpg   DIY - OEM PDC retrofit-06-wp_20140607_008.jpg   DIY - OEM PDC retrofit-07-wp_20140607_009.jpg   DIY - OEM PDC retrofit-08-wp_20140607_010.jpg
rolant (02-18-2023)
Old 06-10-2014, 02:36 PM
heiker's Avatar
heiker
heiker is offline
Sensors installation in the rear bumper
You need to drill 27mm diameter holes in the rear bumper. Tools needed: stepper drill (with the 27mm step) and 3 mm or 4 mm drill (depending on the 1st step of the stepper drill) for punching the centers of the holes.
The bumper has a marked positions of the sensor from the inside (big crosses). In the PDC OM retrofit set except wiring you will get the sensors holders with the adhesive tape. You will beet to paint the holders rings on the matching colour of the bumper. In my case I used 3 spray paints: primer for plastic, white base paint (matched with CM colour code) and transparent paint for shining finishing.
The next step is to drill 27mm holes, where the sensor holders will fit.
1. Protect areas outside the bumper where you will drill holes
2. Drill inside-out 3/4 mm punching hole. You need to match each center of the cross.
3. Drill outside-in 27 mm hole
4. Check fitting of the holder
5. Use alcohol to prepare bumper surface for adhesive
6. Attach each of the holders and use a pressure to stick it to the bumper. Be careful - each holder is dedicated to separate sensor position
7. Plug the sensors into holders. Be careful - each of the sensor is dedicated and factory pre-coded to match one of the positions. When plugging sensor into holder you should hear 'click'.
Final bumper view with PDC sensors installed
Attached Thumbnails DIY - OEM PDC retrofit-10-wp_20140607_012.jpg   DIY - OEM PDC retrofit-11-wp_20140607_014.jpg   DIY - OEM PDC retrofit-09-wp_20140607_011.jpg   DIY - OEM PDC retrofit-12-wp_20140607_015.jpg   DIY - OEM PDC retrofit-13-wp_20140607_016.jpg
rolant (02-18-2023)
Old 06-10-2014, 07:06 PM
mikey_t's Avatar
mikey_t
mikey_t is offline
Well done and an excellent write-up!
Old 05-31-2015, 12:03 PM
Boneman's Avatar
Boneman
Boneman is offline
Thanks for the info. Not sure what you meant with the coding part and some of your other acronyms/ abbreviations. Can you expand on those a bit please?
Old 05-31-2015, 01:41 PM
heiker's Avatar
heiker
heiker is offline
Hi Boneman,
Well, at this forum you can find a lot of posts with similar acronyms. Just digg dipper. I am not sure if just writing you the full names of the acronyms will help you more, because you need to understand the whole concept of coding the vehicle first, what IMHO I would like you to encourage to. This post is intended for the guys familiar with coding. You can find many of the posts describing coding.
Here are the full names of few acronyms
VO Vehicle Option
FRM Fussraum Module
ECU Electronic Control Unit
PDC Parking Distance Control
Old 06-02-2015, 11:37 AM
Boneman's Avatar
Boneman
Boneman is offline
I found a part number for a retrofit kit - 66202183710 - is this what you used?
2017jcw (09-21-2017)
Old 06-02-2015, 11:51 AM
heiker's Avatar
heiker
heiker is offline
Yes, but note that this kit consists only with OEM wiring set and sensors holders. You need to purchase separately sensors and control module /PDC ECU.
Old 09-17-2015, 06:40 PM
MDR60's Avatar
MDR60
MDR60 is offline
Hi,
I would really appreciate if you can send me the manual for installation.
thanks..
Old 09-17-2015, 06:48 PM
MDR60's Avatar
MDR60
MDR60 is offline
Hello Heiker,
First of all, thank you for sharing this important and helpful DIY project. I am really interested in installing the OEM PDC retrofit. I would appreciate it much if you can share a scanned copy of the manual for installation as i plan to purchase the whole kit for my unit. can't wait. hope to hear from you soon.
Good day,
MDR60
Philippines
Old 10-13-2015, 10:19 PM
Ambidexter 211's Avatar
Ambidexter 211
Ambidexter 211 is offline
Thumbs up Console photos please!
Hi,
Great...another item to add to my "what to get for my 2013 Countryman S All4" list! :D
If you can, please show us the end result...the PDC being displayed on the OEM screen in the front.
Also if the coding changes have told the car this is a factory install, then aftermarket backup cameras should detect the PDC and display it as they expect?
Oh, and the document for install would be good, as well as where you get the other parts...unless that's in the doc.
Cheers & Happy Motoring
-Ambidexter
Old 10-16-2015, 10:24 AM
heiker's Avatar
heiker
heiker is offline
I have just Mini Boost CD, so no display of PDC sensors. Just 'beeps' in the speakers. However if you have Mini Navi and camera, then after retrofitting PDC and coding all ECUs, the PDC proximity bars should be visible on the display when reversing.
Parts were collected from the dealer (wire harness and brackets for sensors), ECU and sensors were used from other crashed Mini CM.
Installation instruction you will get for free at your dealer - it is instruction for PDC retrofitting, as this is official retrofit, like racing fron lights, you can DIY.
Old 02-23-2017, 10:22 AM
Dimitris Sofianopoulos's Avatar
Dimitris Sofianopoulos is offline
hello there, I am trying to create my own wiring for oem pdc. I have the Bentley manual and from the electric diagram I cant find the x8090 and x8091 connections where the position 8 and 2 goes to. Position 7 goes to position F30 at fusebox with 5A fuse. Position 12 goes to ground. Every sensor has 3 pins inside. Could somebody help me???
Old 04-19-2018, 08:38 PM
Mod-Mini's Avatar
Mod-Mini
Mod-Mini is offline
Has someone been able to verify what comes with the retrofit kit 66202183710? Does it have clips for the back of the bumper? I have a R55 WITH PDC and trying to install an aero bumper WITHOUT PDC. I have procured the PDC trim pieces which solves this problem for the two outboard positions. However the painted bumper just has markers to drill holes but no way to clip sensors in.
I only need the clips, I have everything else. If there is a cheaper way to get those clips or some other way that they might be held in, would be interested to hear!
EDIT: Found clips searching for "BMW PDC sensor clips" on ebay - we'll see if they are the right ones but looks good for now!
Quarky42 (02-19-2023)
Old 05-29-2020, 01:50 PM
Konstantinos Mouchalos's Avatar
Konstantinos Mouchalos is offline
Pdc retrofit
Originally Posted by heiker
Dear all,
Hardware added:
- 4 sensors
- OEM wiring set
Coding:
pdc retrofit
Hello great job you ve done there. I followed your instructions and now everything seems ok except from wiring the module with the car. The sensors are connected with the module already. I need if it is possible more info about the wiring of the module with the car
Old 02-18-2023, 07:08 PM
Quarky42's Avatar
Quarky42
Quarky42 is offline
Can you edit the title to include Parking Sensor Retrofit? I'm VERY glad I found your amazing thread (no thanks to the forum search). I'm doing this exact job in the very near future. You've helped me out a ton! I couldn't tell if the retrofit kit had the adhesive mounts in it or not. Sounds like it should. Great news.
Old 02-19-2023, 07:05 PM
mikey_t's Avatar
mikey_t
mikey_t is offline
Dont hold your breath waiting for Heiker. He hasn't been here on this forum for quite a while.
Old 06-15-2023, 07:39 AM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
We have pictures of the kit on our site and the mounts look to have double sided tape.
https://www.ecstuning.com/b-genuine-...t/66202183710/
PDC control unit
https://www.ecstuning.com/Search/Sit...h/66209252640/
PDC sensor
https://www.realoem.com/bmw/enUS/sho...diagId=66_0216
Pick the oem 11 digit and the part number (color of your bumper) and pop it into our site, we have some aftermarkets in black/ non colored to save money.
Stock black with aftermarket: https://www.ecstuning.com/Search/Sit...h/66209196705/
Old 01-17-2024, 11:27 AM
Gijzzy's Avatar
Gijzzy
Gijzzy is offline
This topic got me to this forum, great information and gave me the idea to do this retrofit myself.
I have gathered all the parts but didn't expect to have to pin out the connectors myself, so that is my first challenge and hopefully somebody can help me with the manual or someone who has done it him (or her) self.
The connectors on the PDC sensors I will try to copy the pinout of an other Mini, but if somebody has got clear pictures they are welcome
Ground point wouldn't be hard to find
​​​​​​But
To what pin does the power wire go in the connector that goes into the Fuse Box (JBE SPEG). I probably will be able to find by plugging in and out the PDC fuse and check the pins but would be easier to just know.
And where is a good place to splice the CANbus signal. Can I just find the CANbus wires near the fusebox and splice it or need it to be on a specific place?
Thank you guys for the help and I will keep you updated.
Old 01-17-2024, 12:41 PM
Just saw this, the PDC unit and install kit are still available at this point.
On the pin out tool.
https://www.ecstuning.com/b-schwaben...ieces/ce-70-2/
Install DF attached
File Type: pdf
CountryJim (01-18-2024)
Old 01-18-2024, 03:51 AM
Gijzzy's Avatar
Gijzzy
Gijzzy is offline
Thank you so much! This is a great help and will save me serious time.
Old 01-18-2024, 09:18 AM
Awesome, glad to help
user 73920
11-25-2021 12:47 AM
froggio
05-10-2021 07:04 PM
minicooperjp
08-20-2020 12:06 PM
CRC
02-24-2020 09:08 AM
bullit 2496
Electrical
15
04-19-2012 08:15 AM
Quick Reply: Interior/Exterior DIY - OEM PDC retrofit
