Interior/Exterior Aftermarket Steering Wheel Install
Old 01-04-2014, 08:42 PM
ColoradoDrake's Avatar
ColoradoDrake
ColoradoDrake is offline
So I bought my Mini a few months back and the biggest thing i wanted to cange was the wheel... i mean... look at it.
So I went to work, and have been accumulating parts over time. Today everything came in! My main concern with this was the plastic tab that operates your auto turn-off feature of your turn signals. I tried my luck at the problem and I shaved it down until the hub was tight enough on it to where it would move with it. Not perfect, nor permanent, but I didn't have the patience to do anything else yet here is the finished install with my quick release and where I leave my wheel when I'm parked. Enjoy!
Old 01-05-2014, 01:50 AM
MCSJCW06MX's Avatar
MCSJCW06MX
MCSJCW06MX is offline
Nice, are you planning on making it a racing mini or just didn't like the oe wheel? Aren't you concerned what will happen in case of an accident? I mean you removed the airbag.
Old 01-05-2014, 02:53 AM
minsanity's Avatar
minsanity
minsanity is offline
Track/rally steering wheels normally don't have airbags, so w/ old school cars decades back. That's the trade off. The tired 2 spoke wheels are the only aesthetic flaw to gen1 MINIs. I had to swap mine out, too. Instead of shaving the plastic tab, I copied the hole diameter & location of the OE hub & drilled 1 into the aftermarket 1. Works like a charm. Here are a coupla mine:
Old 01-05-2014, 09:21 AM
ColoradoDrake
Minisanity, I'll have to do that in the near future! As for the no air bag problem. I run scroth harnesses and enjoy the feeling of them being tight so I'm not going to go anywhere! I also auto x the mini Yes and having the racing wheel and having it closer makes a huge difference. I dig the mini button on your wheel too! Where you pick that beauty up?
Old 01-05-2014, 09:48 AM
BlwnAway's Avatar
BlwnAway
BlwnAway is offline
Min. helped me with my install also, here's mine:Name:  IMAG0537.jpg
One thing to mention/pay attention to, "diameter" if like me you have a chrono pack you may have problems seeing your gauges (tach, speedo) with the wrong diameter wheel.
Old 01-05-2014, 11:31 AM
ColoradoDrake
Good God all those gauges are sexy!
Old 01-05-2014, 12:37 PM
BlwnAway's Avatar
BlwnAway
BlwnAway is offline
Lol, I went a little control crazy as far as early warning & just keeping an eye on things.
All VEI. All Electronic w/ custom setable threshold alarms.
Dash:
Boost
Volts
(open spot - moved my fuel psi.)
Dual IAT
Column Left:
Fuel psi.
Nitrous psi.
Column Right:
AFR
(Future W/M)
Old 01-05-2014, 01:17 PM
ColoradoDrake
I'm thinking of mounting boost on the left with afr on the right and then converting an old shift light I had on my 73 Mach one to work above the tach. All in due time though!
Old 01-05-2014, 02:46 PM
minsanity's Avatar
minsanity
Agree on having it nearer. On the button, get 1 where you can insert a decal under the removable clear acrylic. I simply customized w/ 3M reflectorized sticker backing & black vinyl overlay (w/ MINI cut out). Wanted the OEM+ look.
Blwn, always good to see pics of your mods. It's 2014, hope it's now where you want it to be!
Old 06-03-2014, 03:58 PM
ishoelaceee's Avatar
ishoelaceee
ishoelaceee is offline
What hub are you using with the NRG quick release?
Old 08-03-2017, 11:20 AM
Walter O's Avatar
Walter O
Walter O is offline
What's your go around for the disabled airbag? Doesn't the car freak out and throw a code only the dealer can clear?
Old 08-03-2017, 06:41 PM
RudeJoe's Avatar
RudeJoe
RudeJoe is offline
There's a thread here (I believe or maybe YouTube) that gives information about using seats without airbags. Those guys used a 2 ohm resistor between contacts to fool the system so no airbag lights. Not sure if the steering wheel airbag works the same way but its worth a look.
Old 02-24-2018, 05:44 PM
Ankersen21's Avatar
Ankersen21
Ankersen21 is offline
Steering wheels
is that a short or a tall base for the wheel adapter?
Old 04-29-2019, 04:27 PM
caaaarrrrrrssss's Avatar
caaaarrrrrrssss
caaaarrrrrrssss is offline
What about the wiring?
Hello
reading through this because I’ve just taken the wheel off my r56 and put an OMP one on but, how do I connect up the horn/turn off the airbag warning light? The connectors for the wheel controls are there but do I need an adapter?
Someone please help!
Old 04-29-2019, 08:10 PM
OCR's Avatar
OCR
OCR is offline
There should have been instructions to read on this info.
There should also be connectors and short wires to allow plugging in the horn button, and a 2ohm for ("hopefully") turning off the airbag light. Mine didn't work, doesn't bother me anymore..! But my horn does work.
If you have no instructions, call the manufacturer or go digging into You-Tube. Both are actually pretty simple.
Mike
Old 05-13-2019, 12:06 PM
putttn's Avatar
putttn
putttn is offline
Size
I’m considering OMP, Recaro and some others but not sure what size from hub standpoint and circumference. What are you folks suggesting.
Old 11-03-2019, 08:40 PM
minsanity's Avatar
minsanity
07-16-2020 12:54 PM
nomar116
08-14-2015 04:54 PM
skippermini
08-12-2015 10:05 PM
nomar116
08-12-2015 05:24 PM
MES11
Navigation and Audio
08-06-2015 08:52 AM
Quick Reply: Interior/Exterior Aftermarket Steering Wheel Install
