Interior/Exterior Mini LED fog light
Old May 23, 2013 | 06:49 PM
  #26
SuperGreg's Avatar
SuperGreg
Originally Posted by Chibi-Mini
here we go , it got 2 fogs and a control box. now i need to find a installation guide......
LED is 6000K
Damn, no guide in the box? That sucks
Old May 24, 2013 | 01:33 AM
  #27
rkw's Avatar
rkw
Does anyone has access to the Mini Catalog can help for installation guide????
Instructions in German: http://www.mini2.info/forum/attachme...8&d=1366880978. However, you should ask the vendor if they have the English pdf.
Old May 24, 2013 | 01:42 AM
  #28
Angib's Avatar
Angib
Attached is a rather poor copy of the useful pages of the English-language guide.
But you should see this excellent photo/write-up on a British Mini site by someone who has fitted them themself:
2nd Gen DRL Fitting Guide
Ah, but of course your car will be left-hand drive, so you may need to remove the wiper motor and not the battery - see the German guide above which Google will sorta translate for you.
File Type: pdf
Old May 26, 2013 | 08:49 AM
  #29
jns2001's Avatar
jns2001
Anyone already installed it in the US?
Old May 26, 2013 | 08:58 AM
  #30
SuperGreg's Avatar
SuperGreg
Chibi-Mini above will probably be the first in this forum.
Old Jun 2, 2013 | 08:45 PM
  #31
praecurvo's Avatar
praecurvo
I am officially subscribed.
Old Jun 4, 2013 | 04:32 PM
  #32
nd3boy's Avatar
nd3boy
Any updates?
Old Jun 4, 2013 | 05:03 PM
  #33
rkw's Avatar
rkw
Originally Posted by nd3boy
Any updates?
All the activity has gone to another thread: https://www.northamericanmotoring.co...ls-fitted.html
Old Jun 26, 2013 | 03:30 PM
  #34
Chibi-Mini's Avatar
Chibi-Mini
Finally had time installed, gonna post it after the rain outside . ugh..
Impression - Match the stock HID color
1 - Full LED circle only in DRL mode
2 - If head lights on only top half circle on
3 - If Fog light on then top half circle and both fog LED on
Old Jun 26, 2013 | 03:39 PM
  #35
SuperGreg's Avatar
SuperGreg
Looking forward to getting a pair!
Old Jun 29, 2013 | 03:15 PM
  #36
Chibi-Mini's Avatar
Chibi-Mini
Pics Up
Old Jun 29, 2013 | 03:25 PM
  #37
SuperGreg's Avatar
SuperGreg
Pics Up
That is just too cool looking!
Old Jun 30, 2013 | 03:51 PM
  #38
Chibi-Mini's Avatar
Chibi-Mini
Old Jul 1, 2013 | 04:13 PM
  #39
bmrguy03's Avatar
bmrguy03
Can't wait for mine
Old Jul 2, 2013 | 03:07 PM
  #40
Elbkind's Avatar
Elbkind
Any idea who the manufacturer might be, markings or logos on the part? Hella, Osram, Marelli, ZKW, Valeo ... ?
Old Aug 10, 2013 | 01:11 PM
  #41
TJANK's Avatar
TJANK
I really would like to know how easy it was to install these awesome lights? Did you find installation instructions for these lights? Was there new wiring or was it plug and play. I assume the instructions were not in box.I found the MSRPof £399.00 from the Genuine Mini UK accessories catalog. The exchange rate is terrible to US$620!
Old Aug 10, 2013 | 01:21 PM
  #42
SuperGreg's Avatar
SuperGreg
I recently bought for $450 delivered to AZ. Install was easy, I paid my MINI guy $135 to do it :P
No Instructions included. New wiring and control module.
Old Aug 10, 2013 | 02:42 PM
  #43
Chibi-Mini's Avatar
Chibi-Mini
Everything are plug and play except 1 blue wire need to pass the firewall to connect to the module in the foot well.
Old Aug 10, 2013 | 04:50 PM
  #44
TJANK's Avatar
TJANK
Good to hear! They are only [SIZE=3][FONT=Calibri]£297.01including VAT($460) at minigenuineparts.co.uk.[/FONT][/SIZE]
[SIZE=3][FONT=Calibri][/FONT][/SIZE]
[FONT=Times New Roman][SIZE=3][/SIZE][/FONT]
Old Aug 10, 2013 | 05:05 PM
  #45
SuperGreg's Avatar
SuperGreg
Good to hear! They are only £297.01including VAT($460) at minigenuineparts.co.uk.
That's where I got mine. DHL will also bill you for duties for about $15. Keep in mind, it's more time consuming than it sounds. You either have to pull the front bumper or headlights just to remove old units if you have a HT. also battery cover, installation of module etc...
Old Aug 18, 2013 | 05:38 PM
  #46
TJANK's Avatar
TJANK
I received the instructions to install these. Seems fairly straight forward. The only question I have is that after running the single blue wire through the rubber grommet into the interior of the car. It says to connect BL (blue wire), to the cable from Pin 12 of plug X14261, SW (black) 51-pin socket housing, of the footwell module. OK, how do I know which of the 51 wires is Pin 12?
Old Aug 18, 2013 | 07:04 PM
  #47
rkw's Avatar
rkw
Connectors normally have tiny numbers molded into the plastic. The pins might be individually numbered. If the pins are spaced too close for individual numbers, only the first and last pins in each row are numbered, and the pin number is counted sequentially going down the row. The numbers may be on the side of the connectors rather than the top.
Anyway, I Googled X14261 images and this was a result:
It would be the 12th pin from the right in the bottom row. Check the markings on the connector to confirm.
Old Aug 19, 2013 | 10:48 AM
  #48
Angib's Avatar
Angib
Yes, the end pins are numbered so you can work out which is pin 12. The bit nobody mentions is that you need to release the multi-pin plug from a housing that locks it to the module.
This photo from 'Caveman Daves' excellent guide to fitting the DRLs shows the plug slid halfway out of the housing (with the grey over-centre locking lever):
While the plug is still in the housing, you can't see the pin numbers, or indeed which wire goes to pin 12! That had me worried at that point.
Some British installers have reported that they do not have a blue wire in that pin, but I'm not sure if that means they were looking at the wrong plug or the wrong pin, or if they really are different wiring colours.
If this doesn't sound easy, that's because this wasn't intended as a owner-fitted accessory - it's only really meant for Mini dealer installation, hence the lack of a single installation guide.
Old Aug 19, 2013 | 02:39 PM
  #49
TJANK's Avatar
TJANK
These posts have been extremely helpful! Thanks. I ordered the LED lights along with extra plastic pop rivets. (BLIND COMPRESSION RIVET #51118222901 $0.99; EXPANDING RIVET51770382696 $2.63;EXPANDING RIVET #: 51717002953 $0.99;20mm Expanding Fastener#51471911992 $0.99). I assume I be able to reuse compression rivets, but not the expanding ones.
Old Aug 19, 2013 | 03:04 PM
  #50
SuperGreg's Avatar
SuperGreg
Good for you. You will love them!! BTW, no need to remove front bumper at all. This can be done by removing the front headlights!!
