Interior/Exterior Proclip Center Mount (iPhone & iPad Content)
iPhone mounted using Proclip's center mount, multi device adapter, and adjustable iPhone mount.
iPad mounted using Proclip's center mount, multi device adapter, 1.5" right spacer, and iPad mount.
Above, but landscape.
iPhone holder is great, and mostly the primary thing I use. I stream pandora via bluetooth mainly, and use TomTom.
iPad holder is functional, but excessive and I can see it being a distraction. It takes a little room away from the passenger, but you can shift without any interference (thanks to the spacer...otherwise you'd be screwed).
It's important to note that the Proclip holder uses the gap between the CD player and wraps around the trim (piano black in my case) on the center console. Two things. The ProClip mount was very thick where it pushed into the gap where the CD player was. I was able to carefully use the dremel with a sanding tool to remove material until it fit, and would not distort or damage the OEM plastic. Also, I was concerned that the clip would eventually scratch or mar the piano black plastic trim. To prevent this, I installed some clear bra material (Avery Nano Fusion it happens) on the piano black trim. The installation is solid, and shouldn't cause any damage with use.
Do you have any details of your Ram Mount? I have been researching other mounting options other than the ProClip center mount. I even prototyped a mount that uses a bracket and comes from the glovebox, but the sheet metal I used was too thin and the mount vibrated/bounced with the phone/ipad attached.
I might be interested in the Ram Mount if it's a cleaner solution than the proclip.
Here are links to the parts that I found and ordered off Amazon and also some pics of it installed. You can read the reviews of the mount or Google it for other photos. I do have the upright post stabilized partway up with a velcro strap attached to the shifter pod/cup holder surface.
*Edit: Sorry for size of pics. I will try to reduce size and repost. Edit Done.*
RAM MOUNT POD I UNIVERSAL NO-DRILL VEHICLE MOUNT
RAM Tab-TiteTM
RAM Tab-TiteTM
And sorry to the OP, not meaning to hijack your thread. I would still like to see some more closeups of the Pro Clip where it attaches to the dash.
Attached some photos of the mount. I recently reinstalled it. Replacing the double sided tape with some wider strips. I also reinstalled the paint protection film on the piano black trim. Lastly I sanded the proclip mount to be a little thinner and more conformed to where it inserts between the CD player and trim.
07-16-2020 12:54 PM
08-12-2015 01:24 PM
08-07-2015 05:55 AM
