Interior/Exterior Moss mini magnetic hood strips
Old Jun 9, 2011 | 12:40 PM
minimiker53's Avatar
minimiker53
i took the hood strips off on cooper today and the people who put them on the used a heat gun and ruined my paint under the stickers but be that as it may! i have to cover it back up and but was wondering is any one has put the magnetic strips on from moss mini??? it seems easy to put on but i really was wondering wat they looked like! if anyone does have them can u post pics?? thanks
Old Jun 9, 2011 | 03:03 PM
smieska's Avatar
smieska
I started with magnetic bonnett stripes and thought they looked very good after trimming them to fit perfect. I did however have them come off twice in a very strong cross wind before I put on the vinyl. I have a friend who has had his magnetic stripes on for 2 years and never had them come off. Actually his magnetics I thought were vinyl until I looked close one day and I explained my wind removal. He said he has never had that problem. Good luck with your decision
Old Jun 9, 2011 | 03:21 PM
Capt_bj's Avatar
Capt_bj
got pictures? cuz I've never heard of this. people use heat to remove stripes but not to apply ... usually.
What's the damage?
You are not seeing paint fading are you?
Old Jun 10, 2011 | 04:59 AM
signcarver's Avatar
signcarver
not sure if it's the same for the stripes but...
i can tell you that when we make magnetic signs we recommend that the user removes and cleans both the vehicle and the back of the signs once a week.
If you don't do this, moisture can form under the sign and cause pitting in your paint.
Old Jun 10, 2011 | 04:36 PM
minimiker53
here some pics! the bad spot is on the drives side! it looks like the paint was heated up to me!
Attached Thumbnails Moss mini magnetic hood strips-img_20110609_131550-1-.jpg   Moss mini magnetic hood strips-img_20110610_165710.jpg
Old Jun 10, 2011 | 07:06 PM
Cooper06's Avatar
Cooper06
I'd go back with the adhesive vinyl. I had a company put viper stripes on mine and they came out looking excellent. If you use the magnetics you'll have to worry about fading, cleaning, etc. Other than the spot you have at the top of the hood is there fading?
Old Jun 11, 2011 | 05:27 AM
minimiker53
I think I am going back with one vinyl off center strip down the drivers side to cover that spot up!!also has anyone painted there hood scoop with plaits dip??
Old Jun 16, 2011 | 03:38 AM
soccerbummer1104's Avatar
soccerbummer1104
are you 100% sure thats jot just dirty vinyl adhesive residue? in the picture that's what it looks like to me. give it a good rub, and maybe try some goo-off.
Old Jun 16, 2011 | 06:56 AM
yetti96's Avatar
yetti96
I did my scoop on my R56 in Plasti-Dip.
Old Jun 16, 2011 | 07:15 AM
vkash1208's Avatar
vkash1208
I agree with soccerbummer, it looks like adhesive, I can't imagine a heatgun causing that much damage from applying vinyls. With the amount of heat needed to damage the paint, it would melt and ruin the vinyl as well.
Old Jun 16, 2011 | 04:01 PM
minimiker53
100 % sure!! i got all the adhesive off!! it under the clear coat!!! i dont think theres anyway of fixing it with out repainting the whole thing so i might just get a off center racing strip and cover it back up!!
Old Jun 16, 2011 | 05:28 PM
vkash1208's Avatar
vkash1208
My offset stripe
Old Jun 16, 2011 | 05:39 PM
minimiker53
looks good man!! im thinking both black!! btw which headlights are those?
Old Jun 16, 2011 | 07:03 PM
vkash1208's Avatar
vkash1208
Stock, I two toned joey modded them and put in LED accents under the little spots on top of the projector lens.
Old Jun 16, 2011 | 07:28 PM
5zero4's Avatar
5zero4
That is bizarre, but it is not from using a heat gun. You would have to keep the gun on one area and basically burn the paint to get even close to that, but it would look totally different. That and you would destroy the vinyl in the process.
I would suggest that the hood has been resprayed at some point and has reacted to the vinyl.
I had a red car once that had a white decal "tattoo" the paint with a slight blue tinge. If the stripes were on for a long time, it may be a reaction from that.
Come to think of it, I remember removing a wrap on an R53 that left a stain in the same position on the hood. What is under there? It may have had something to do with the ink though.
On another note, I had some magnets on the side of my car (Astro black) for about 3 weeks. One came off at some point on the 405, and it had left a "stain", which kinda looked like the magnet had drawn the metallic flake closer to the surface (under the clearcoat) and was lighter in appearance.
It did end up going away after a few weeks though (phew).
Good luck on that.
Old Jun 16, 2011 | 08:04 PM
MisterClean's Avatar
MisterClean
The magnetic stripes are kinda weird...it's hard to recommend them because it depends on your wants. It rains a lot where I live and it was annoying taking the stripes off after every day it rained. If you don't take them off often then moisture gets underneath the stripes and causes...a "fog" stain for a few days. For me I just didn't want to mess with them however they are cool because you can choose when to have stripes and when not to.
The key point with the magnetic stripes is that you need to clean underneath them often (especially after raining).
Old Jun 18, 2011 | 08:18 AM
minimiker53
Thanks guys! I'm prolly going with vinyl strip
marendt428
Feb 25, 2016 07:13 AM
O4mcs
Aug 10, 2015 10:22 PM
Aug 7, 2015 05:56 AM
