Interior/Exterior How safe are carbon fiber doors?
Old Sep 9, 2010 | 08:33 AM
donjulio's Avatar
donjulio
Seibon makes cf doors.
Anyone have some input on side impact safety compared to the oem doors?
Old Sep 9, 2010 | 11:16 AM
ZippyNH's Avatar
ZippyNH
Watch out....they are made for racing....I know many folks that bought their hoods wish they had their old metal ones.....I know folks had tons of issues with the hoods flexing...alignment, etc....there is also issues with protecting the CF from UV light....
This is a mod made to reduce the cars weight...as a race car....I would do other things first...like remove carpets, sound deadening, radio, AC first. I suspect that this mod is generally aimed at folks that have a roll cage....and that cage would provide much of the crash protection....(and keep the car stiff, since the doors help to stiffen the car). I bet CF would provide very little crush protection in an accident....I bet it would shred...
Old Sep 9, 2010 | 02:21 PM
fusion's Avatar
fusion
Hi I heard that CF has problems with heat and UV light. Many people paint the CF hold to try to protect it. Also I heard CF is brittle and can shatter, more so in the winter. It depends on how the part was produced also. Since it is a racing aftermarket part, they might not have strict standards as OEM car parts.
Old Sep 9, 2010 | 03:31 PM
03miniac's Avatar
03miniac
^What they said.
CF last i looked doesn't wrap around edges to under sides. Instead CF over fiberass shell is cut close to edges, painted black & finally gel coated. I can't imagine fitment & gaps would be perfect.
Good luck!
Old Sep 11, 2010 | 06:53 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
They also have electrical grounding issues......they just don't make a decent ground for varouis NEEDED components for your car.
Old Sep 11, 2010 | 08:36 AM
ZippyNH's Avatar
ZippyNH
On a side note....CF may be stronger POUND per pound, but as we have found in aviation, it must be CAREFULY designed for each application to work correctly....just making a flat surface out of CF, and making it light...I bet there was no/little engineering testing...While CF is strong pound per pound,it lacks penetration protection...and that is what you need in a door.........sure you might keep the door protection beam in the middle...but you might not, and that provides some stiffness/protection...but I bet the edges of the door would come unglued and get pushed in like a rag in a side impact...
Now, if it was a track car....with a full roll cage, Go for it!! It will help to lessen the impact of the cages weight, and maintain the aerodynamics!!
Old Sep 11, 2010 | 09:44 AM
Porthos's Avatar
Porthos
Since when do they do bonnets, boats, and doors in CF on an R56? And if you decide to get CF either paint it or have clear coat put on it and it will be fine. Accidents happen and if you get hit in the right way it won't matter what the material is.
Old Sep 11, 2010 | 09:53 AM
iwashmycar's Avatar
iwashmycar
youd need a cage. thats whatll save your life, not the doors
Old Sep 11, 2010 | 12:10 PM
donjulio's Avatar
donjulio
I only want CF components because they don't rust! My 7 year old mcs is starting to rust. I plan on keeping it forever and not wanting to deal with rusting parts.
Hey raven u moved it to the wrong forum, make it go back to first gen lol.
Old Sep 11, 2010 | 01:36 PM
Porthos's Avatar
Porthos
If your MINI is starting to rust go get it fixed. MINI has a 12 year rust protection guarantee.
Old Sep 11, 2010 | 01:47 PM
MotorMouth's Avatar
MotorMouth
CF doors on a street car would be insane.
CF hoods on street cars is stupid. If you got into a bad front end crash, instead of crumpling, the hood would come straight through your windshield and decapitate you.
Old Sep 11, 2010 | 07:42 PM
03miniac's Avatar
03miniac
Good call. Never thought about that.
Better get a CF hood also.
Old Sep 12, 2010 | 08:55 AM
donjulio's Avatar
donjulio
Considering that the hood is locked down in 4 places and its wider than the windshield, and was able to stay intact and not splinter during the crash,
worse case scenario - detach from front end and bounce off windshield/a pillars
Old Sep 12, 2010 | 09:30 AM
iwashmycar's Avatar
iwashmycar
yeah if you get decapitated by a hood, it was just meant to be lol
Old Sep 12, 2010 | 09:42 AM
rkw's Avatar
rkw
They also make a CF rear lid. Shouldn't be much of a safety issue there.
Old Sep 12, 2010 | 10:03 AM
MotorMouth's Avatar
MotorMouth
those "locked" places will splinter and act as if they aren't even there.
I'm there sure are a few police officers and paramedics who would back me up.
Old Sep 12, 2010 | 10:32 AM
ScottRiqui's Avatar
ScottRiqui
With the door, it depends on how much of the door you're replacing. The factory door skin is just that - a "skin" that wraps around the edges of the door frame. You can remove it by grinding around the edges of the skin to release it from the frame. All of the structural support beams that you'd care about in a crash are in the frame itself and wouldn't be affected by removing the skin.
Of course, if you're just removing the metal door skin and bonding a CF skin in its place, I don't know how much weight you'd be saving.
Old Sep 12, 2010 | 10:55 AM
drewstermalloy's Avatar
drewstermalloy
Seibon only makes CF stuff for 1st gen cars.
Old Sep 12, 2010 | 01:53 PM
rkw's Avatar
rkw
Seibon does the entire door. Without a cage and door reinforcements, it wouldn't be safe in a crash.
http://www.seiboncarbon.com/product.php?product_id=822&
Old Sep 12, 2010 | 05:15 PM
KC Jr 54's Avatar
KC Jr 54
Straight CF apparently has the REALLY bad habit of splintering into razor sharp shards when broken.
CF Doors = racecar only. Kinda like how a cage is mildly retarded in a street driven car.
Old Sep 13, 2010 | 09:44 AM
03miniac's Avatar
03miniac
Easy fix for car cancer.
http://www.arizonajobs.com/
http://www.architecturaldigest.com/a..._homes#slide=5
bavmotors
Oct 13, 2015 12:43 PM
dube53
R58 :: Coupé Talk (2012+)
Sep 11, 2015 09:30 AM
M7Speed
Sep 3, 2015 07:48 AM
Ntety
Sep 2, 2015 08:39 PM
