Interior/Exterior Hood Scoop/Turbo Heat Shield QUESTIONS
Old Jul 10, 2010 | 10:03 PM
ZJedi945's Avatar
ZJedi945
I have just noticed that my hood scoop on my '07 and started to see it deforming. One thing I wanted to ask, do they replace it at the dealer for little or no charge? I am hearing mixed things about it so I thought I would ask.
Ok now to stop what has been happening..... I am looking at 2 shields...
First the NM Engineering heat shield...
http://www.outmotoring.com/mini-coop...at_shield.html
Second the M7 Aerogel turbo heat shield...
http://www.m7tuning.com/parts/produc...f76b937e8b00e3
I just want to know how both are, what are the people that have them think?
Old Jul 10, 2010 | 11:34 PM
gepperso's Avatar
gepperso
Interested to know also.
Old Jul 11, 2010 | 12:39 AM
aaronvb's Avatar
aaronvb
Ok no to stop what has been happening..... I am looking at 2 shields...
I have the NM Titanium Heat Shield and the hood/hood scoop is noticeably cooler than before. It's still pretty hot, but not as extreme as it was before.
I can't say if it has helped with the warping as I haven't had any warping yet. And I can't comment on the M7 either.
The NM was easy to install, 10 minutes. Just make sure you wait for that turbo to cool down(maybe 2 hours) before going near it. The NM also looks pretty slick and the build quality looks top-notch.
I would also suggest drilling out ALL of the holes in the hood scoop grill. I think the older MCS's don't have any holes, and the newer MCS's have some holes but not all of them are drilled out.
Old Jul 11, 2010 | 11:07 AM
Porthos's Avatar
Porthos
Well MINI needs to get off their *** and release the fix for the hood scoop. It is suppose to e a metal reinforced plastic that is not suppose to warp but, it was suppose to be out 4 months ago.
Old Jul 11, 2010 | 01:01 PM
iwashmycar's Avatar
iwashmycar
best thing to get would probably be a turbo wrap in lieu of a shield. Would probably cut more heat than a shield.
Old Jul 11, 2010 | 01:08 PM
cop1406's Avatar
cop1406
I have the M7 on my car and have had no problems with warping yet. I have put my hand on the hood of the car after running it pretty hard, and although it is pretty warm, it is not hot enough to burn your hand. See my gallery for a picture of it installed.
Larry
Old Jul 11, 2010 | 01:58 PM
david in germany's Avatar
david in germany
I went with the simple fix, JCW CF scoop. I have over 45k miles since install and no issues yet.
Old Jul 13, 2010 | 10:18 PM
rans09vert's Avatar
rans09vert
I have the M7, it looks factory, and the hood is not as hot.
Old Jul 14, 2010 | 01:28 AM
10Zero's Avatar
10Zero
I have a NM heat shield and really like it. I went one step further and lined the under side of it with heat reflective material, which helped a lot too. Picked it up at Advance Auto for $20.
http://shop.advanceautoparts.com/web...7CGRP2039P____
Old Jul 14, 2010 | 02:45 PM
The QZ's Avatar
The QZ
They should replace the warped scoop under warranty. It is a known issue. I had 3 scoops replaced under warranty and finally got them to replace it with the jcw carbon fiber version. I also installed the m7 heat shield for good measure. After a week it's still good.
Old Jul 14, 2010 | 02:55 PM
wrx_xb9r's Avatar
wrx_xb9r
I have the NM shield and love the look. It also keeps the scoop cooler. Probably going to put it on the wife's clubbie also.
Old Jul 18, 2010 | 08:25 PM
rans09vert's Avatar
rans09vert
I read in another post here that the heat sheilds will keep the heat in the turbo, and ultimately cook the turbo. Is this correct? As I have an M7 version, and that would not be good. I would think that both manufacturers of these heat shields would have thought about that.
Old Jul 19, 2010 | 07:51 AM
wrx_xb9r's Avatar
wrx_xb9r
The turbo has a built in cooling system. That system runs even after you shut off the engine. You should not have any issues with "cooking" the turbo.
Old Jul 19, 2010 | 04:56 PM
Porthos's Avatar
Porthos
Well since MINI has not released there supposed fix they are warrantying the hood scoop with the JCW CF one. They did mine last week and it looks awesome.
Old Jul 19, 2010 | 05:04 PM
ZJedi945's Avatar
ZJedi945
Whoa whoa whoa wait a second here, what did you do? Where did you go? HOW?
Old Jul 19, 2010 | 06:48 PM
Porthos's Avatar
Porthos
Tom Bush MINI and they warrantied it for free no charge.
Old Jul 19, 2010 | 07:59 PM
gawannamini's Avatar
gawannamini
I did the same and so far (5k miles) no warpage of the JCW carbon fiber scoop.
Old Feb 15, 2011 | 10:55 PM
Bruinjustin's Avatar
Bruinjustin
is this only known issue for upto 2010 models or 2011 models as well?
have they released the fix for 2011?
I am still under break in period so I haven't run my mini hard enough yet, but I can feel hood gets REALLY REALLY hot.
Old Feb 15, 2011 | 11:13 PM
OctaneGuy's Avatar
OctaneGuy
This problem was fixed on 2010+ models. I've got a 2010 Clubbie with the redesigned hood scoop...but I opted to replace it with CF for looks lol.
Old Feb 15, 2011 | 11:41 PM
Bruinjustin
yeah.. i saw yours, Richard.
is there article for that?
Old Feb 26, 2011 | 11:48 PM
djdraddy's Avatar
djdraddy
I had the same problem with my stock hood scoop. My friend actually burned his hand pretty badly on my hood one day so I got the M7 Aerogel heat shield. I also got their Ram-2 scoop. They work well and my hood is only just warm now. I highly recommend the M7 heat shield to anyone with a turbo Mini.
Old Mar 5, 2011 | 06:11 AM
MINI*8R's Avatar
MINI*8R
Only problem with M7 Aerogel heat shield is that it is not designed for the new 2011 MINIs. The '11s have an engine cover over the valve body which causes the M7's frame not to fit. However, if you cut the "L" piece off the shield and file it down, it will fit. I'd get the NM if I had to do it over (may get the NM anyway).
Old Mar 5, 2011 | 12:12 PM
djdraddy's Avatar
djdraddy
As you can see I have a number of NM parts on my car, but I didn't care for their heatshield. It gets way too hot and then just becomes a heat radiation source itself. I like the M7 with the aerogel pad under the metal plate. The aerogel pad works so well that I can almost touch the plate moments after stopping. You can't do that with the NM, but it does look flashy.
As far as the 2011's go I don't know what fits or doesn't fit, but the OP was talking about his 2007. I'm sure given a little time, Peter at M7 will make a version for the 2011's and on.
Old Mar 5, 2011 | 12:40 PM
white rocket's Avatar
white rocket
I run the M7 shield with no complaints whatsoever. Looks factory with great fitment. I'd recommend it to anyone.
Old Mar 5, 2011 | 12:59 PM
MINI*8R's Avatar
MINI*8R
Are you running a 2011 MCS? The engine cover changes the fitment, which is why I had to cut the "L" piece off. And, by the way, the NM does not necessarily fit the '11s either. Just FYI.
