Interior/Exterior Rear Seat Delete + Spare Tire Mount
Old Sep 23, 2009 | 07:36 PM
BentChainring's Avatar
BentChainring
First off, removing the rear seats is amazingly easy. Wow, 5 minutes and their out.
I wanted to remove them to get some ideas about what I want to do with the area which was formerly my rear seat. And it got me thinking about integration of the spare tire with a DIY RSD kit.
One other person on this board did make a RSD kit with integrated spare tire storage, and I did like it. I was thinking however, of a rigid mount to prevent the tire from become a projectile in case of an accident, and from moving all together. Has anyone built a mount to interface with the rear seat mount (and the center of the rim)? I noticed it used a heavy steel bracket mounting with two bolts and a Pin.
Has anyone fabricated a spare tire mount to interface with this bracket? And also possibly the seat belt brackets? Keeping the tire level will ensure that in an accident the tire is loading the mount in shear. The rest of the RSD kit will be carpeted, including a carpeted cover for the tire.
Thoughts?
Old Sep 24, 2009 | 05:24 AM
Creeve's Avatar
Creeve
I made a custom rear strut bar after my RSD. It could easily be used as a solid mounting point for a spare tire.
Old Sep 24, 2009 | 06:01 AM
BentChainring
What are those two pads for?
Old Sep 24, 2009 | 07:53 AM
Creeve's Avatar
Creeve
They are the former rear headrests now jumper seats.
Old Sep 24, 2009 | 08:00 AM
malteseracer's Avatar
malteseracer
That looks really cool man
That is mine. Been thinking about making it cooler and stronger. I like the schroth mounts in the center because ill get one eventually. I dont have the skills to make what you did, but maybe I'll drill some holes and put in some 1x1s.
Whats a Jumper seat? (Forgive me if thats a noob question)
Old Sep 24, 2009 | 09:05 AM
Creeve's Avatar
Creeve
jump seat:
movable or folding seat, as in a carriage, taxicab, or limousine, used as an extra seat.
Old Sep 25, 2009 | 06:41 PM
willsblackmini08's Avatar
willsblackmini08
Where did you get that kit?
Old Sep 25, 2009 | 07:54 PM
malteseracer
Helix. You made ur own if I recall right?
Old Sep 25, 2009 | 09:24 PM
willsblackmini08
Not yet I have not had the time. I should have it done and Monday and I will have a few up for sale in the market place.
Old Sep 26, 2009 | 06:23 AM
malteseracer
If they come out really finished I'll buy one from u. I'd offer to run over there for the day either sat or sun but I have work.
Old Sep 26, 2009 | 09:27 AM
willsblackmini08
Yeah I have for all weekend. Monday will most likely be the first day I can tackle this project. Maybe tonight if I'm lucky. As soon as I have it made I'll have pictures up and everything. I wouldn't mind turning this in to a very small side business
Old Oct 2, 2009 | 02:22 PM
willsblackmini08
DONE!!!!
Old Oct 2, 2009 | 08:40 PM
malteseracer
Well done man. That hook there is a T40 if you want to remove it. Are you using it for anything?
Old Oct 3, 2009 | 09:00 AM
willsblackmini08
No i'm not using it for anything i just left it in case I ever have to put the back seat in. Plus to get it out I would have had to undo some of the RCB which I was not in the mood for. If you want one the other two I have cut I didn't cut the spot for the seat mount in them yet.
Old Oct 3, 2009 | 10:19 AM
malteseracer
I could use the cloth wrapping you have on there for the plastic one I have. Does yours flex to use the space underneath as storage?
Old Oct 3, 2009 | 11:48 AM
willsblackmini08
What do you mean by "flex to use underneath as storage". The cloth wrapping on a plastic one would be a bit tough. Attaching the cloth to the backside of it will be the hard part.
Mine needs a little fine tuning. I should have it completely done on Tuesday night.
Old Oct 3, 2009 | 07:11 PM
malteseracer
Mine flexes so that I can pull it up and put stuff under it. I keep a spare set of clothes, some car care stuff etc etc. Also helps to put some pillows or something under it to reduce the road noise back there. You could use actual sound insulation, but who goes that far honestly :P
kazyn
Oct 25, 2019 02:34 PM
mishanja
Jun 22, 2016 09:59 AM
Mini'mon
Aug 26, 2015 01:02 PM
Mrdi
Aug 7, 2015 01:06 PM
