Interior/Exterior $53.00 and 2-1/2 hours later...
Old Apr 7, 2009 | 04:32 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
I love the side stripes made by Aesthetic Creations, but lacked the full expertise of installing them. Dealers charge a bundle, and body shops are not much better.
So back in January, I won an ebay bid I never expected to win for a complete HAMANN MINI Cooper Body Decal kit which included door kick plate decals, bonnet, boot and sides. My winning bid was $53.00 bucks and was shipped frm Great Britian for about 10 dollars.....
I cleaned the MINI's paint surface with Dawn Dish washing liquid to remove all wax buildup and then clayed the surface. I feel the clay is a very important step in the process of prepping the paint surface, especially if your MINI is as old as mine is.
I used a mixture of a minute amount of Dawn and water in a spray bottle and a hard plastic squeegee with a chamois lip. And used a small plastic ruler to make sure the decal letters were level with the bottom of door jam.
After pressing the water out from the decal using this wet application method, I let the decal cure to the paint for about 20 minutes, then sprayed the backing with the same mixture of water and soap, then carefully pulling the backing away from the cars surface, removing any bubbles by carefully rubbing my thumb across them while peeling it back. Used a razor blade at the door openings making the cuts in the middle of the openings so there is enough decal to make it curl around both side edges. Using a hair dryer at this step helps to make the edge ahere and curl around the door lip ect. Just a LITTLE heat goes a long way.
Applying the side decals took only 2.5 hrs, and I had no helpers. Got my feet wet doing the bonnet and boot.
So if you have been a bit sheepish of doing this yourself, all I can say: It's a lot easier than you think. Give it a try.
Old Apr 7, 2009 | 04:36 PM
M3NTAL's Avatar
M3NTAL
Are you planning on putting any other Hamann parts on your car?
Old Apr 7, 2009 | 04:47 PM
-=gRaY rAvEn=-
Moderator
HAMANN makes awesome stuff, but is very expensive. Nah, just I did this to get my feet wet before spending some 200 bucks for a nice kit from AC.....It's a really long trip to Mike's from Massachusetts.
Old Apr 7, 2009 | 06:18 PM
xnotfunkylex's Avatar
xnotfunkylex
Looks good. Glad to here it wasn't to difficult.
Old Apr 7, 2009 | 06:32 PM
CR&PW&JB's Avatar
CR&PW&JB
Nice job !
I really like those bonnet stripes ! I'm digging the side-stripes, too. Not sure yet on the boot decals. Different, for sure.
Way to You-ify your MINI.
Old Apr 7, 2009 | 06:40 PM
ricbow's Avatar
ricbow
great first effort!
Old Apr 7, 2009 | 06:51 PM
-=gRaY rAvEn=-
Moderator
Originally Posted by CR&PW&JB
Nice job !
Thanks, I am with you on the boot stripes too. I may just end up getting some plain black Viper stripes for the boot and see how that looks. The mix match pattern seems a bit to busy.
Originally Posted by ricbow
great first effort!
Thanks Rick, Weather here finally cooperated in a joint effort. Been sitting on this project for while now.
Old Apr 7, 2009 | 08:38 PM
Carlisle's Avatar
Carlisle
What a gorgeous MCS. I am in awe. Congrats!
Old Apr 7, 2009 | 10:16 PM
MrCooperS's Avatar
MrCooperS
Moderator
Hey Alec, that looks awesome dude. Are you going to paint the rest of the black vinyl body color?
Old Apr 8, 2009 | 06:48 AM
freez3's Avatar
freez3
From: United States of America, Ohio, Stark County, Uniontown
You did a very nice job.
You've got a great lookin' MINI.
Old Apr 8, 2009 | 11:37 AM
Malcon's Avatar
Malcon
i like it! looks nice
drrigg
May 27, 2022 03:31 AM
Doc Pain
Mar 10, 2021 04:50 AM
OutMotoring
Nov 16, 2015 07:04 AM
silence2-38554
Sep 28, 2015 12:19 PM
EVMini
Sep 28, 2015 10:20 AM
