Interior/Exterior Removal of circular vent
Old Mar 14, 2009 | 03:45 PM
MiniPOLACK's Avatar
MiniPOLACK
i need to remove one of the circular vents located next to the steering wheel, whats the procedure for that? i dont want to break anything with my big hands , lol
Old Mar 14, 2009 | 06:49 PM
misslindsey's Avatar
misslindsey
The ones on either side of the speedo? As I recall those are all part of the speedo trim. You have to pull off the dash trim (or just open the secret compartment on that side, which exposes a few screws on either side. Then there's the screws on top of the speedo inside the vent. Look up a thread on installing a Kuda mount or a toggle switch and there's lots of detail on taking that stuff apart.
Old Mar 14, 2009 | 07:05 PM
Lovemonkey's Avatar
Lovemonkey
you lose something inside o-0?
Old Mar 15, 2009 | 02:25 AM
MiniPOLACK's Avatar
MiniPOLACK
i would like to install a boost gauge there
Old Mar 15, 2009 | 02:27 AM
MiniPOLACK's Avatar
MiniPOLACK
wait a minute what secret compartment? is there another secret compartment besides the one on the passenger side? i need to pull off the vent thats next to the RPM meter to the right.
Old Mar 15, 2009 | 07:29 AM
misslindsey
Heh... no, that secret compartment.
Try here: https://www.northamericanmotoring.co...hardwired.html
And here: https://www.northamericanmotoring.co...al-on-r56.html
For how to get all that stuff apart. I got as far as taking the ring around the vent off, but didn't care to take the vent out, so I don't know exactly how it comes out. The trim around the vent is attached to the trim around the speedo, is attached to the trim around the vent on the other side of the speedo (by the secret compartment) which is what makes it complicated.
Good luck! Let us know how it works out and looks when it's finished!
Old Mar 15, 2009 | 09:59 AM
MiniPOLACK's Avatar
MiniPOLACK
thank you very much, its a great help...ill post few photos of the aftermath
Old Mar 19, 2009 | 04:17 PM
MiniPOLACK's Avatar
MiniPOLACK
ok, new plan...i need to remove the air vent that located next to the driver door...i cant seem to find anything that will let that vent out :(...hheeelllpppppp
Old Apr 17, 2009 | 11:30 AM
playtowin's Avatar
playtowin
Did you ever figure out how to remove the vent next to the drivers door? I have a rattle in mine and I want to remove it to see if I can figure out what is vibrating.
Old Apr 17, 2009 | 02:31 PM
MiniPOLACK's Avatar
MiniPOLACK
yes....you have to remove the plastic trim behind the RPM meter. then remove the bottom part of the dashboard that located underneath the steering wheel ( 3 screws from bottom or pedal area) after removing that, you will uncover on of the screws that hold the vent. then pry on the side plastic that located right next to the vent ( it can only be pried on when you open the door , its sort of shaped like a letter U ). when you look at that driver side door vent, its to the left of the vent, behind it you will find like 2 screws that hold the actual vent. now theres one more screw right underneath the A-pillar plastic, i didnt attempted to get to it, becasue i didnt needed to, but i think you have to get the a-pillar off to get to it..hope that helps.
cub4bearindiana
Jun 30, 2016 06:11 AM
Crimguy
Sep 10, 2015 01:07 PM
ltjpunk7
Sep 6, 2015 07:32 AM
greekzilla
Aug 23, 2015 03:44 PM
Shane Wendel
Aug 21, 2015 01:04 PM
