Interior/Exterior Aftermarket OIL temperature gauge
Old Nov 22, 2008 | 04:12 AM
William Blake's Avatar
William Blake
I'm looking for a nice looking and clear oil temperature gauge for the R55 S.
I think BMW made a huge mistake in not including these gauges on a 'high-performance' car. One should always know how the car in running..
I know ALTA has water temp (which is pointless, it's the oil temp. that really counts) and a boost gauge...
Any other alternatives?
Thanks in advance
WB
Old Nov 22, 2008 | 09:04 AM
SmokeM's Avatar
SmokeM
How is measuring water temp. pointless? It raises/lowers in direct correlation to oil/engine temperature temperature?
Old Nov 22, 2008 | 09:16 AM
William Blake
It's not pointless but many people still think they can give their car the beans as soon the water temp is settled to operating temperature.
Which is not true! Your oil is what lubricates the engine!
Old Nov 22, 2008 | 09:46 AM
pillar's Avatar
pillar
yeah... i always thought oil temperature was a more direct way of measuring operating temperature...
Old Nov 22, 2008 | 11:27 AM
ghosthound's Avatar
ghosthound
QFT!!!
water temp can be at temp well before oil temp is even near optimum operating temp. Id want to get oil temp, oil pressure, and boost.
Old Nov 23, 2008 | 05:17 AM
William Blake
Anyone?
Old Nov 23, 2008 | 07:26 AM
austex's Avatar
austex
How about this:
http://www.sw-performance.com/index....tails&p=114267
Closest match I can find to stock gauge face.
Old Nov 23, 2008 | 09:02 AM
MINIdave's Avatar
MINIdave
My '03 has a factory oil temp gauge, do they not offer it anymore?
Old Nov 23, 2008 | 09:03 AM
Quesera's Avatar
Quesera
I've never heard that expression before. What one learns on NAM!
What about that devide that plugs into the cars diagnostic port (Scanguage???) Would it give that kind of info?
Old Nov 23, 2008 | 09:07 AM
Quesera's Avatar
Quesera
I just checked and while scangauge offers 12 digital gauges, oil temp is not one.
I have the controversial chrono pack, by the way, which may or may not just be a dressed up idiot light.
Old Nov 23, 2008 | 09:34 AM
not-so-rednwhitecooper
It is an idiot light. Just like water temp on a regular speedo.
And Scangauge can only show you what the car has sensors for. Oil temp is not one of them.
Old Nov 23, 2008 | 09:36 AM
You probably have the Aux Gauge Pack under the switches then, that was a dealer installed option.
All the cars some straight from the factory with ONLY a water temp "gauge", the rest are idiot lights.
Old Nov 24, 2008 | 12:14 AM
William Blake
Originally Posted by austex
How about this:
Not bad, but it's in F°.. we use the metric system here.
Nope, a true shame!
lol
Scangauge is nice but a bit tacky and it doesn't show oil temp.
Chrono pack? Never heard of it
Old Nov 24, 2008 | 12:29 AM
ScottRiqui's Avatar
ScottRiqui
I don't know where this idea got started (that the Chrono Pack is just 'an idiot light with needles'), but I just don't see it.
When my car's warming up, the oil and water temp needles climb up from ambient temperature to normal operating temperature - they don't immediately swing into place, and if I shut the engine off but leave the ignition on, I can watch them gradually come back down as the engine cools off. Likewise, the "normal" position of the needles varies depending on how hard I'm driving the car and how hot it is outside, so the needles aren't "locked in place" once the engine's up to operating temperature . I've even intentionally forced the engine to run slightly hot by blocking off a portion of the radiator, and the coolant temperature needle reflected the higher coolant temperature.
The Chrono Pack coolant temperature gauge may be electronic and driven by the same sensor that the scangauge would read, but I'm pretty sure the oil temp gauge is a standard electric gauge with its own sender. Likewise, I know that the oil pressure gauge is a standard electric gauge with its own sender.
Old Nov 24, 2008 | 12:42 AM
ScottRiqui's Avatar
ScottRiqui
It's a first-gen option only (so far). It moves the speedometer onto the steering column next to the tachometer, replacing the speedometer with gauges for fuel level, oil pressure, oil temperature and coolant temperature.
Here's a picture from BlimeyCabrio's car:
In the picture, you can see that the car's still warming up (or it's very hot outside) - the coolant temperature gauge is up to about 110 °F, but the oil temperature is still pegged low. Also, even though the car's probably idling, the oil pressure is up at 35 psig, indicating that the oil's still cold.
Old Nov 24, 2008 | 06:55 AM
William Blake
OMG! That's brilliant!
But WHY don't they offer it anymore? :(
Old Nov 24, 2008 | 07:18 AM
ScottRiqui's Avatar
ScottRiqui
I don't know if it wasn't a very popular option on the first-gen cars, or if MINI is trying to push more people toward the NAV package (which obviously isn't compatible with the Chrono Pack, since they both occupy the same real estate on the dash.)
Old Nov 24, 2008 | 10:13 AM
ChubbyChecker's Avatar
ChubbyChecker
Try this one, Metric 2-1/16" Oil Temperature, 60-160°C, Electric, Silver Dial.
Old Nov 25, 2008 | 09:35 AM
William Blake
Originally Posted by ChubbyChecker
Nice!
It does look very difficult to install..
Old Nov 25, 2008 | 10:43 AM
austex's Avatar
austex
Originally Posted by ScottRiqui
[...], but I'm pretty sure the oil temp gauge is a standard electric gauge with its own sender. Likewise, I know that the oil pressure gauge is a standard electric gauge with its own sender.
Scott,
Can you tell where the oil temp sensor/sender is for your ChronoPack? Drain plug is a common place (my Volvo, some VW's), but on a Gen2 Mini with low clearance and down-facing drain, not sure that's a good idea.
Old Nov 25, 2008 | 11:07 AM
ScottRiqui's Avatar
ScottRiqui
I believe the sender is on the engine block, near the oil filter housing. I'll have to find a picture to narrow it down further. I know that neither the Chrono Pack oil pressure nor oil temp sender are in the drain plug, although if you got the dealer-installed auxiliary gauge kit (the one that went between the downtubes on the dash), that kit *did* use the drain plug for the sender.
TREX
Nov 2, 2019 07:31 PM
Tylerlanger1
Aug 21, 2015 03:03 PM
finn
Aug 21, 2015 07:59 AM
tylewis
Aug 18, 2015 06:53 AM
