Interior/Exterior DIY blackout HL & TL rings - grill surround R56S guide
Old Jun 3, 2012 | 01:30 PM
  #276
kel3q3's Avatar
kel3q3
Originally Posted by fherrle
Update on my black out.
So the bleach did not work as well as I had hoped.
Plan B: I have connections at a local plating shop, they were able to soak off the chrome in the nitric acid tank.
this worked very well, I have fresh plastic parts to lay down my paint. I had one part that the clips had broken off so I was able to test on this one first.
NOTE: best to remove all of the plastic tabs, I left the one that screws go into and they melted away, different kind of plastic.
I had to strip and repaint the headlight rings, I got in a hurry and the paint was not fully cured, left fingerprints. we finnaly have weather in the 70's so I am hoping to have finished in the next week.
The wife keeps giving me a bad time about my car missing parts and looking like crap.
Just wondering if you completed this mod? How did it go? What materials did you use? I'd like to do some work like this, but I'd rather use a paint or vinyl instead of Plastidip (thought I may try that on my emblems).
Old Jun 5, 2012 | 01:17 PM
  #277
JPR18's Avatar
JPR18
Alright, so I dipped my grille today.
The top was very easy...remove the screws, pinch the tabs, easy out.
The bottom was not so easy. I tried pulling on just the chrome part after releasing the tab on either side, but it was pulling the grille with it. So I popped the 4 rivets on the grille (easy) and removed the entire grille (easy). I thought I could just tape off the grille part and spray the chrome....bad idea. Don't do this. After two coats and an hour, removing the tape removed about half of the paint on the grille. So, I had to remove the chrome part afterall. With a little bit of patience, a flathead screwdriver, and 10 minutes, I had it free and it was so much easier to paint.
Old Jun 6, 2012 | 08:28 AM
  #278
mikeyb74's Avatar
mikeyb74
Looking good! I lost my patiences with plasti dip when I did attempted it.
Old Jul 6, 2012 | 06:44 PM
  #279
orbitup's Avatar
orbitup
Just finished spraying my trim. I still have to do the mirrors, handles, and emblems. I wish I could put them on now!!
Old Jul 7, 2012 | 09:15 AM
  #280
orbitup's Avatar
orbitup
Done and on.
Old Jul 23, 2012 | 11:55 PM
  #281
tommydh's Avatar
tommydh
i know this is an old thread but I was thinking of doin the blackout with the black chrome dupli color paint. Has anyone used that yet I didnt bother going through whole thread.
Old Jul 24, 2012 | 07:36 AM
  #282
2HIP's Avatar
2HIP
Painting the chrome would take some serious prep, sanding, etching primer, etc. Adhesion would always be an issue IMO
Plasti Dip requires degreasing the piece and it STICKS. Easy to take off and chips would be easy to fix.
Old Jul 26, 2012 | 12:27 AM
  #283
tommydh's Avatar
tommydh
The kit is called Shadow its by Dupli- color. Its designed to paint over chrome to give it the Black chrome look with minimal prep. No sanding I plan on doing it this weekend will post pics.
Old Jul 27, 2012 | 08:32 PM
  #284
Jr Sabino's Avatar
Jr Sabino
Thanks for this thread! I just recently did it a couple days ago, and i enjoyed it so much, that i decided to also do my hoodscoop, side emblem, and i even made some eyelids on my Headlights. Love the results. thanks for the tips!
Here are some pictures:
http://www.flickr.com/photos/67680109@N03/7659916932/
http://www.flickr.com/photos/67680109@N03/7659916498/
http://www.flickr.com/photos/67680109@N03/7659915830/
Old Aug 7, 2012 | 03:29 PM
  #285
absoluteczech's Avatar
absoluteczech
those that have done this can they report back on durability? how is it after 1 year in the sun, and being blasted by the sand on the road. also how is when washing/drying the car? does it leave black smudges? is it chipping/fading?
Old Aug 18, 2012 | 09:54 PM
  #286
Lazlo10S's Avatar
Lazlo10S
Just did my grille, HL & TL rings, and side markers today! Looks great! Thanks to all who posted in this thread. Very helpful.
Old Aug 26, 2012 | 06:28 AM
  #287
chinq6t's Avatar
chinq6t
After 4 years posting this thread
I'm glad to see so many owners putting this simple affordable style mod to good use.
For any one who's on the fence, I've touched up maybe once every two summers depending how bad the winter was.
It chips, but so does your car paint. So it requires infrequent touch ups that you can't necessarily with your exterior paint.
I can honestly say plastidip is a durable product for the exterior that requires little maintenance and can be removed at your convenience. The only hassle is removing your chrome accents with finesse.
It does not smudge, and washing is a breeze. Keep in mind it's meant for tool grip so if you try to clean with an abrasive, it'll cause friction.
I'll post pics soon of my 2 year old plastidip touch up.
Old Aug 27, 2012 | 10:38 AM
  #288
SmokeM's Avatar
SmokeM
After 3+ years, I've taken off my plastiDip headlight trim. It was looking rather beat up. It held up great over the years but the rock chips and salt and lack of upkeep did them in.
Taking it off was a breeze. If you have a spot where it's lifting, you can use a hose to get alot of it off. For the thinner hard to get off areas I used goo off or goo gone. Soak a rag, wipe the plastidip and off it comes. The chrome finish was left unharmed. Although, I did not leave the goo off sit or soak. The chrome looks great, like it was brand new but I will probably spray them again when I have time. If you're on the fence, try it. Just make sure you put lots of coats on so it's nice and thick (if you spray it under the sun, it drys very fast). If it's thick, you can peel it right off and won't need goo off. It is a very good product.
Note, I wouldn't use it on the gas cap. If you live in a state where they pump your gas, they'll get gas on it and it leaves a mark. I would probably do this over in the body color and not dipped.
Old Aug 28, 2012 | 03:51 PM
  #289
absoluteczech
plasti dip headlight and tail light surrounds
http://www.flickr.com/photos/absoluteczech/7865350698/http://www.flickr.com/photos/absoluteczech/7865350698/ by http://www.flickr.com/people/absoluteczech/, on Flickr
http://www.flickr.com/photos/absoluteczech/7865352738/http://www.flickr.com/photos/absoluteczech/7865352738/ by http://www.flickr.com/people/absoluteczech/, on Flickr
Old Sep 5, 2012 | 08:41 AM
  #290
jenkman's Avatar
jenkman
How did you get the S red on the scuttles? Did you mask them?
Old Sep 9, 2012 | 11:52 AM
  #291
NewCooperFanatic's Avatar
NewCooperFanatic
Just did all the chrome on my R58....anyone have issues with washing the car with the plasti dipped pieces?
Old Sep 9, 2012 | 12:59 PM
  #292
automan21's Avatar
automan21
No problem at all.
Old Sep 10, 2012 | 10:30 AM
  #293
NewCooperFanatic
Originally Posted by automan21
No problem at all.
Very cool! Looks like I'm washing a car today
Old Sep 10, 2012 | 01:20 PM
  #294
absoluteczech
yea no issues. i wouldnt scrub the plastidip very hard, but its held up pretty well so far.
Old Sep 17, 2012 | 04:22 PM
  #295
orbitup's Avatar
orbitup
No, I sprayed the whole thing and traced the "S" with a blade and pulled it off. I did the same thing with my emblems.
Old Sep 19, 2012 | 07:04 AM
  #296
Lazlo10S's Avatar
Lazlo10S
Nice job on the emblem I've been back and forth between painting and removing my emblems, but i think I'll try spraying them first
Old Nov 1, 2012 | 12:27 PM
  #297
john171's Avatar
john171
Originally Posted by Josh P.
Do you know how much plasti dip is? I spent less than $8 and did my HL, TL, and grill trim last night. Driving lights are a PAIN IN THE AS$ to get back on. But here is the finished product...
Needs a bath, but I absolutely love it. I need to do the belt line next.
Josh, how did you do the belt line with the PlastiDip?
Looks good by the way!
Old Nov 1, 2012 | 06:39 PM
  #298
blakeslee_a's Avatar
blakeslee_a
Use a razor blade and cut around the edge and peels right off
Old Nov 21, 2012 | 09:14 AM
  #299
BJM's Avatar
BJM
Figured I'd show off mine a little as well. I had my first experience with plasti dipping this morning. Needless to say, I love this stuff.
I don't want to go overboard with this stuff, but I'd like to do the chrome strip on the trunk lid, as well as the chrome strip in the lower grill.
Old Nov 21, 2012 | 12:06 PM
  #300
wzabrouski's Avatar
wzabrouski
Wrapped in vinyl. I got tired or reapplying pastidip after rock chips.
