Interior/Exterior Removing Shift Knob on an Automatic Transmission?
Old Mar 13, 2008 | 08:10 PM
wetceal's Avatar
wetceal
Removing Shift **** on an Automatic Transmission?
Hey Everyone,
I did a search for this but couldn't find anything pertaining to an automatic R56. Does anyone know if the procedure to remove an automatic shifter on the R56 is the same as removing the manual shift ****?
Thanks,
Celia
Old Mar 14, 2008 | 06:09 AM
Partsman's Avatar
Partsman
Legion_of_Doom
I just asked one of the techs, we did one not that long ago, he said it pulls right up like the manual trans one.
Old Mar 14, 2008 | 07:48 AM
lxjose9xl's Avatar
lxjose9xl
Correct, just pull with enough force. Just make sure to get your head out of the way. I almost gave myself a black eye.
Old Mar 14, 2008 | 11:37 AM
earlgrey's Avatar
earlgrey
It's really not easy to pull it out. But after changing to the Craven ****, you will love to hold it more.. hehe..
Old Mar 15, 2008 | 07:29 PM
MLPearson79's Avatar
MLPearson79
Pull. Like really hard. If you have a sunroof, open it first. Watch your teeth.
Old Mar 15, 2008 | 07:36 PM
wetceal's Avatar
wetceal
Thanks for the instructions and advice everyone! I really appreciate it. Do you guys know if I need to hold the shift button down on the automatic while I'm pulling?
Thanks again!
Celia
Old May 24, 2008 | 10:21 AM
zanydr's Avatar
zanydr
shift **** manual or auto removal
rest board on seats then used big 90 degree pry bar claw end under lip of **** with cloth to protect ****. great leverage removed **** EASY! replace **** in correct position then protect with cloth or anything that will do and tap lightly with medium ball peen hammer. you will see it go down enough right away. normal force will not budge it. this method leaves face,teeth,nose,back of head and sunroof intact. pushing the button does not matter.
Old May 24, 2008 | 03:48 PM
wetceal's Avatar
wetceal
We actually removed it pretty easily using the method that most people referred to - We put the parking brake on, started the car and shifted it into neutral so the shifter is more centered (and easier to pull straight up on), put one leg on either side of the shifter on the floor of the car, open the sunroof so that you can stand up and stick your head out of the sunroof and then just pull straight up. It comes right off pretty easily. This is what we did for the automatic transmission. We did push the button while pulling up on it but you might not have to...
Old Sep 20, 2008 | 09:46 AM
rackops51's Avatar
rackops51
Just to second the above post... I was pretty skeptical about pulling out my automatic shifter as there just HAD to be some connection somewhere to allow the mechanical stop to function. Well, I figured I could pay for another if I needed to, so I took the plunge.
Pulling on it from the driver's seat didn't work very well, so I centerlined myself (lifted the armrest and opened the sunroof) and gently applied increasing pressure. I'm a pretty athletic guy - and my **** was a bear to remove! I finally got it off though, and was able to put on my new shift boot.
Never thought that the parts went together like that!
Dave
Old Sep 20, 2008 | 09:49 AM
rackops51's Avatar
rackops51
By the way, I should add in here that I have an R53 MINI, and it worked just like the R56 shifter.
Old Sep 20, 2008 | 12:35 PM
Robin Casady's Avatar
Robin Casady
What are people doing once they have the shift **** removed on the Auto?
Old Sep 20, 2008 | 02:28 PM
rackops51's Avatar
rackops51
Well, to be truthful, I looked at it for a while, played with the button to see the cool lock go up and down, then tossed it on the dash while I did my work.
OH...so why did I take it off?
Seriously, I got a really cool four panel red and black shift boot from redlinegoods.com. They don't normally do four panels for automatics, but I begged them and they did it. It looks SWEET.
Dave
Old Apr 17, 2011 | 02:37 PM
bbemslie's Avatar
bbemslie
gear shift romoval
Thanks again!
Celia
IS THIS REALLY TRUE TO REMOVE THE SHIFTER?
Old Apr 17, 2011 | 02:39 PM
bbemslie's Avatar
bbemslie
Gaer Shift Removal
We Have A 2004 Cooper Automatic. I Have Read The Post Of Removal By Just Prying Or Pulling Up With Brute Strength. Is This For Real?
Old Apr 17, 2011 | 04:16 PM
NavyNUKE's Avatar
NavyNUKE
so an almost 3 year old thread was opened randomly, i'll add to it, does anyone make aftermarket shift ***** for the automatics?
Old Apr 21, 2011 | 12:57 AM
donuttang's Avatar
donuttang
i did it before but now i the little clip has no function, i can just move from P to D without holding on that clip...
something must be broken....
Old May 10, 2011 | 08:46 PM
Cory949's Avatar
Cory949
What I noticed with my shifter ****
I have a 2007 automatic R56 Cooper S. To release the **** I put my fingers on either side of the chrome "Park" release lever and pulled it toward the dash while wiggling. The assembly pulled free as a unit. The chrome lever and black plastic housing (including the pin-lever that releases the Park engagement) slid right out of the shifter.
Then I did the pull technique as described. After reassembly of the shift **** on the shaft, insert the chrome park release assembly back into the shift ****. Flex the chrome lever while doing so to seat the pin-lever into the hole in the Park release shaft. If you do it wrong, the "Park Lock" release will not function. This simply means the vehicle could be accidentally knocked out of park and roll.
Hope this helps
Old May 14, 2011 | 07:44 AM
donuttang's Avatar
donuttang
can you give me a little more detail on how to put it back? the shift lock isn't working on mine, i just tried again in many way of putting it back, the shift lock still doesn't work.....
Old Dec 19, 2011 | 05:52 PM
sillyboybmxer's Avatar
sillyboybmxer
is there any reason the locking mechanism would not work???? a friend of mine had some work done at the dealer and it came back not working,.....tried complaining, got no where. So i ordered her a new one for christmas but before we install it i would like to make sure the one thats on there is not still usable.....im not really understanding what the person two posts above this one is saying, it sounds like the shift **** is two seperate parts ???????? since i dont have the mini here i cant go really examine and the new **** is not here yet, and if i am not mistaken, the new one comes attached to a long rod that goes to the shift linkage?? ....is this correct?
Old Dec 20, 2011 | 08:18 PM
Kirby11's Avatar
Kirby11
You're correct - the AT **** has the **** itself plus the button which is connected to the rod that sticks out of the bottom. Normally the rod reaches down and engages the locking mechanism, and when the button is pushed the rod is pulled upward and unlocks the gear selector.
The easiest thing to check is whether the **** is pushed all the way down onto the stem. Give it a firm whack and see if that pushes the **** into place.
If not, it's fairly easy to take apart the ****/button to see if you can find the problem. How to take it apart depends on which model she has. I think Justas use a BMW ****, so Post #8 instruction 3 from here might help. Instructions for taking apart am MCS **** are here.
PM me if you need any help.
Old Dec 20, 2011 | 08:28 PM
chaswyck's Avatar
chaswyck
I was picturing this as I read this posting and it sounds positively dangerous if you're a guy! I couldn't help but wince. LOL
Old Dec 21, 2011 | 07:18 AM
sillyboybmxer
Thanks for the reply kirby.
Do you know if the **** coming from the factory that I ordered will be assembled correctly and that all I need to do is pry off the current one in which the rod comes off with, and then just put the new **** and rod in place and tap it with a mallet? Just getting my eggs in a row here, dont want her to think I don't know what I'm doin LOL.
What is It that the rod attaches to?????? This is so different to me compared to hondas
Old Dec 21, 2011 | 10:42 AM
Kirby11's Avatar
Kirby11
Yep if the **** is where the problem is, you should be able to pry the old one off and pop the new one on. You'll be a superstar!
Picture attached which might help to visualize what you're dealing with. I have no idea how the rod engages the lock mechanism though.
Attached Thumbnails Removing Shift Knob on an Automatic Transmission?-nmi7626.jpg
Old Dec 21, 2011 | 04:42 PM
sillyboybmxer
awesome, thanks kirby. hopefully it makes more sense when the new **** arrives
Old Jan 1, 2012 | 04:24 PM
donuttang's Avatar
donuttang
i tried again, i departed the **** and removed the clip on the top...push the whole thing down, still can move it freely. Then, use a flat screw driver, stick into the hole and give is a little more push, it did lock the selector, but when I put the clip back, it can't unlock...... :( can you take a photo of both when it arrives?
thanks
