Interior/Exterior Add MFSW to non-MFSW 3-spoke wheel ?
Old Jan 29, 2008 | 07:26 AM
HDClown's Avatar
HDClown
Looking at some used 2006 MCS's that have the 3-spoke wheel but no MFSW buttons. Can the MFSW features be retrofitted to the wheel?
I've found posts on people retrofitting existing 2-spoke MFSW to 3-spoke MFSW, but can't seem to locate if you can go from a non-MFSW to a MFSW setup.
Old Jan 29, 2008 | 07:48 AM
03Indigo's Avatar
03Indigo
User Title's are Silly
Old Jan 29, 2008 | 10:12 AM
rkw's Avatar
rkw
To get an idea of what is involved, MotoringFile has the instructions for a 2-spoke MFSW retrofit: http://www.motoringfile.com/howto/MFSW.PDF. The document says 3.5 hours of labor. You would need updated instructions for a 2006 3-spoke but the procedure should be similar. MINI sells a retrofit kit: http://www.realoem.com/bmw/showparts...26&hg=66&fg=95
Old Jan 29, 2008 | 11:50 AM
HDClown's Avatar
HDClown
I read through that retrofit earlier, didn't look too bad. No full dash removal is required from the way it reads, just odometer and tachometer and a few panels access for fuses, etc.
Anyone know the rough cost of the retrofit kit?
Old Jan 29, 2008 | 12:25 PM
rkw's Avatar
rkw
$382 according to pelicanparts.com. You should check with Classic MINI for a discounted price. You will also need to have a dealer program the computer.
Old Jan 29, 2008 | 01:14 PM
MotoringSpeed_gnat's Avatar
MotoringSpeed_gnat
Using the Part # 65-71-0-395-006 from the post by rkw assuming no Steptronic we sell the part for 286.72 Shipped.
MotoringSpeed 214-618-3639
Website coming soon
Old Feb 26, 2008 | 01:39 PM
minigirl78's Avatar
minigirl78
From what I understand all the 2006 MC & MCS already have all the wiring in the wheel, all you need is the panels with the buttons. As someone else mentioned the retrofit kit is like $382 from pelicanparts.com. Should only take about 30-45 mins to change out the panels, but you'll need to take it back to the dealer to have them tell the computer in your Mini to recognize the functions.
I too want to do this to my Mini, and I think I've read nearly every post on this topic, so hope it helps.
Old Mar 3, 2009 | 10:05 AM
purplehaze05mcs's Avatar
purplehaze05mcs
2005 non-mfsw
Does this 2006 wiring info apply to the 05's?
Old Nov 26, 2009 | 07:20 PM
suss1173's Avatar
suss1173
I have an 05 mcs and I have the two multi function panels, from another car, do you think I can use them plug and play, or do I need to purchase retro fit kit?
Old Nov 27, 2009 | 07:11 AM
Professor's Avatar
Professor
The connection under the airbag and wiring should already be in the column. Take the air bag off, plug in the wiring. You might have to go to the dealer to program the function.
Old Nov 27, 2009 | 11:44 AM
suss1173's Avatar
suss1173
I will give it a try. Thanks
Getrieben
Sep 12, 2024 07:03 AM
theblackfalcon
Oct 11, 2015 09:49 AM
Overpolished
Detailing 101
15
Aug 21, 2015 07:19 PM
flredmini
Aug 12, 2015 06:35 PM
