Interior/Exterior The right way to install stripes!
Old Jan 25, 2008 | 11:23 AM
  #26
murky's Avatar
murky
How do you deal with badges and such?
Old Jan 27, 2008 | 12:22 PM
  #27
MightyStripes.com's Avatar
MightyStripes.com
You can take them off and resintall them with 3m 2 side tape or you can cut the stripe to leave a gap around them like the factory stripes have. Its not hard either way
Old Jan 27, 2008 | 12:23 PM
  #28
MightyStripes.com
Originally Posted by kenchan
that is good to know, cause i've done several stripes and they all
turned out nice without much hassle but this particular one was such a
pita to install. :impatient
i think even the dealer stripes come with a paper protective cover
(if i remember correctly) and those are a breeze to install.
YES! The factory stripes have a paper transfertape and are easy to install like ours but cost a lot more $$$
Old Feb 22, 2008 | 08:55 AM
  #29
MightyStripes.com
Just a little bump to the top do to PM's regarding the location of this thread seems its getting a lot of attion on other boards as well!
Old Feb 26, 2008 | 02:53 PM
  #30
dustinhxc's Avatar
dustinhxc
looks great i plan to get bonnet stripes this summer
Old Feb 26, 2008 | 03:08 PM
  #31
smportis's Avatar
smportis
Wax?
Since no one has asked, and it appears in your instructions, how do you recommend removing the wax from the car?
I guess it is not really necessary since everyone likely waxes their MINI 2-3 times per week like I do (j/k).
Seriously, there is usually wax on the car.
Scott
Old Feb 26, 2008 | 03:20 PM
  #32
CR&PW&JB's Avatar
CR&PW&JB
Good question.
I installed one set of stripes by just doing a Dawn wash on the boot. Didn't strip the wax off well enough. When I went to peel the protective paper cover off the stripes, the vinyl pulled up in spots... had to order another set and start all over.
Use some Goof Off or Goo Gone in the area you're going to install the stripes. Then after the stripes have been installed for a few weeks, don't forget to put some wax back on that area.
Old Feb 27, 2008 | 04:58 AM
  #33
MightyStripes.com
You can use Rubbing alcohol or wax and grease remover. Either one works just fine and gets the wax off 100%
Old Feb 27, 2008 | 08:32 AM
  #34
ImagoX's Avatar
ImagoX
+1 on rubbing alcohol - I always swab the area with the 90% stuff on a microfiber rag before application, and I've not yet had any lifting issues, even with Aesthetic Creation's more aggressive film-type backing.
Old Feb 27, 2008 | 08:50 AM
  #35
MightyStripes.com
And thats the right way to do it
Old Mar 25, 2008 | 06:09 PM
  #36
MightyStripes.com
TO THE TOP TO HELP EVERYONE OYUT
Old Sep 30, 2008 | 04:57 AM
  #37
MightyStripes.com
Just letting everyone know 3M Dosnt make there own vinyls there maid by FDC Products and we now purchase direct from FDC!
And a bump to the top to help all with questions!
Old Sep 30, 2008 | 03:46 PM
  #38
smportis's Avatar
smportis
Originally Posted by CR&PW&JB
Good question.
Just be sure you use the ones that smell like oranges, NOT NOT NOT the ones that smell like chemicals (strong solvent smell). I own restaurants, and recently used one of the goo removers that smells of solvents. When I went to remove the sticker on my new 22 quart lexan container, the plastic of the container starting turning to goo itself and dissolving.
I fear that it would have a negative effect on your vehicle's paint if you used that brand. (No, I don't have a bottle right now to clarify which one - just smell it before purchasing it).
Edit - Actually, I think the one that Home Depot sells (now) is the solvent kind....
Old Sep 30, 2008 | 05:23 PM
  #39
MightyStripes.com
That will not damage the paint you can use laquer thinner if you want without damge to the paint. The one we use smells like crap works great and has never ever damaged anyones car and was purchased at Home Depot
Old Sep 30, 2008 | 06:22 PM
  #40
smportis's Avatar
smportis
Ok, good to know. I would not have experimented with my paint though...
It sure did a number on my $30 plastic container.
adrchn
Aug 13, 2019 02:11 AM
STR3T
May 23, 2016 03:27 AM
squawSkiBum
Oct 2, 2015 09:21 AM
bctf1
Aug 6, 2015 12:55 PM
