How install Craven short shifter?
Could someone please tell me how to install a craven short shifter on an 06 mini cooper s?
Not sure if there is a how-to available or not but I can give a general descrption.
1. Get the car up in the air, 4 3-Ton jackstands come in handy. 2. On the interior of the car, lift the trim ring around the shifter. 3. under the car, drop the exhaust. 4. Still under the car, remove the center section of heat-shielding (about 3ft) 5. Remove the dust cap (white cover to the shift mech) 6. Remove cables, There are 2 cables with ball-end connectors, pop those off. 7. Remove the clips holding the cables into the box. 8. Remove 4 Torx 40 bolts 9. Slide out the box and remove the cables. 10. lower shifter assembly 11. pry plastic tabs in the white ring surrounding the ball to relase shifter 12. transfer Oring and Plastic cap from old shifter to the new 13. Use grease or Anti Siese on the ball and cap 14 Reverse steps above to install. Horrible instructions... I know. What I did... Got someone who's done a few to help :nod: :nod: |
Craven Short Shifter
Any body got some instructions with pictures? Thanks in advance..:thumbsup:
There are instructions on their website...
http://www.cravenspeed.com/products/...t-Shifter.html Also, it's for an R56, but NMeng short shift adapter gives some pictures that might help... http://www.nm-eng.com/media/attachments/210_668856_ins.pdf |
Instructions
Originally Posted by Scooter09
(Post 3326605)
Can someone upload a video? Thanks!
+1
