Rattle Can Queen!!!
If this is a silly question, please don't laugh too much...
Is there anything inside to prevent leaves & other debris from getting into the duct?
7th Gear
Jesus that looks sweet... very clean look and it is amazing how it all came together.
Quote:
Originally Posted by gnatster
Here is a much better shot, shows how it all comes together. The ducts, the cowl scoops and Kraft mirrors. Thanks to dickdavid for the image taken today at the MetroplexMini monthly meeting.
Very valid question, not at all silly. Originally Posted by Uber Blu
If this is a silly question, please don't laugh too much...Is there anything inside to prevent leaves & other debris from getting into the duct?
There is nothing to prevent leaves and other debris. I'm not very worried about it. Living in the concrete jungle of the Dallas/FW area there are not that many trees, unlike the when I lived in the northeast. I did drive through a swarm of grasshoppers today and the grills were covered. I know some had to get into the ducts. These were not small grasshopeprs either (picture later). There were no braking issues. The duct points to center of the hub but is a good 2-3" away, most items will just fall away.
Now also being North Tx there are armadillos. I don't think one would fit all the way in and would become lodged. I'll be sure to take a photo.
Rattle Can Queen!!!
Damn...the comment about armadillos & the subsequent visualization caused me to nearly choke on my chocolate milk!Originally Posted by gnatster
Very valid question, not at all silly. There is nothing to prevent leaves and other debris. I'm not very worried about it. Living in the concrete jungle of the Dallas/FW area there are not that many trees, unlike the when I lived in the northeast. I did drive through a swarm of grasshoppers today and the grills were covered. I know some had to get into the ducts. These were not small grasshopeprs either (picture later). There were no braking issues. The duct points to center of the hub but is a good 2-3" away, most items will just fall away.
OK I need a little advice to get my plan of attack together. I've got the none aero bumper and prefer a more "finished" look then the rivet approach. I'm thinking on mounting the brake duct behind the cover and try to get a seamless look. One question I have is about the bumper cover material. How does it cut? Is it a fiberglass type material or plastic? I'm hopeing a plastic so that I can cut the opening just a little small, mounting the duct and use a trim router with a plastic laminate trim bit to fine trim the opening to the duct. Any thoughts on how the cover will react to being cut with a router?
I'm trying to get a junked cover for practice. If I can find one it might answer my questions. I need to find out who installs the aero kits aroung here and what they do with the old covers. Oh yeah,..what flexible 3M adhesive product was used on yours Gnatster? The 3M site list a few.
Quote:
I have no idea as to the actual mix, all I know it is the stuff used for urathane bumper covers. It cures quickly, can be sanded after about an hour.Originally Posted by LEPRACHAUN
I stole the rear rotor pic from you Way...
Hope you don't mind. Need a nice shot for photobucket!
Ummm..Todd...Originally Posted by toddtce
I stole the rear rotor pic from you Way...Hope you don't mind. Need a nice shot for photobucket!
The pictures are mine, the brake ducts are from Way.
No big deal, I'm famous now, my Mini is gonna be on the TCE site!!
I can send you a higher resolution one if desired.
OH MAN!!!!! that looks gooooood!!!
ps. you know im going to have to do that now, right?
Ummm..Todd...The pictures are mine, the brake ducts are from Way.
I'm a little frazzled tonight. I have a GB on hoses for a Marauder eating at by brain!
Cool, thanks for the correction.
Try this one:
http://www.tceperformanceproducts.co...fe%20press.jpg
Quote:
The cover being IDd as urethane helps a lot. I can probably pose the "which to use" question on 3M's web. Thanks for the help and inspiration.Originally Posted by gnatster
Try this one:
Wow. So you have the 2007 Pikes Peak class record! Congratulations! I missed the original announcement, but I found this:Originally Posted by toddtce
I'm a little frazzled tonight. I have a GB on hoses for a Marauder eating at by brain!Cool, thanks for the correction.
Try this one:
https://www.northamericanmotoring.co...d.php?p=350336
Too cool!
Siiiiiiiiiiiicccccccccccckkkk!!!!!!!!!
that's it.
that's it.
Sorry to drag up an old thread but... DAMN that just looks superb !!! Am loving the look of that
Would be interesting to include some matching grills within the intakes - recessed slightly - to avoid anything getting in at the brake... although its probably not needed...
Nice work!
Nice work!
My little dose of LITHIUM
I have been running the ducts for a while now and never had any problem with debris getting in and doing damage, interfering, etc. I did have a problem when driving through 9inch deep water though--the ducts pumped water onto the brakes such that I had a little "can't stop" scare. Fortunately I was driving very slowly at the time...
