New ECS Stainless Brake Rotor Screws & Holiday Sale
Old Dec 6, 2022 | 10:52 AM
ECS Tuning
If you are replacing your brake pads and rotors an important, yet often overlooked step is replacing brake system hardware. If your brake rotor set screws are showing signs of corrosion, a failed attempt at removing may result in a screw that needs to be drilled out.Utilizes T50 internal torx bit fitting which is the same as the Genuine MINI part!
Our ECS Stainless Steel Brake Rotor Set Screws were designed, engineered, tested and quality inspected by our Research and Development team in our Wadsworth, Ohio facility. We strive for the highest level of precision and quality through leading-edge product development technology including FARO laser scanning for reverse engineering and quality inspection, SolidWorks 3D CAD modeling, rapid prototyping utilizing our in-house 3D printer, and rigorous long term product testing.
"Click HERE for the MINI Cooper Stainless Steel Rotor Screws"
Fits:
2002-2015 R50-R59 MINI Coopers
Save money over MINI parts! Many other MINI brands on Sale up to 60% off!!!
NM Engineering, Akebono, Cat Cams, HT, Hengst, Meyle, ALZOR Wheels, Teckniform Wheels, Clutch Masters, Forge Motorsport, M7 Speed, ALTA, Bav Auto, ECS Tuning, Bremmen Parts, K&N, AEM, FTP Motorsport, JM Turbo Coopers, SCHRICK, URO, Valeo, and Many other!
Vinstar LED Lights, Bosch, and PSB Poly Bushings added to the sale!!
Fits:
MINI 2002+
"Click HERE for the MINI Cooper Holiday Sale "
Tires, Wheels & Brakes
Sep 15, 2020 07:32 AM
Sep 27, 2018 07:51 AM
Sep 27, 2018 07:50 AM
Jul 20, 2018 07:24 AM
Jul 20, 2018 07:23 AM
