Removing coolant reservoir r56
Hello all ,
Anyone know how to remove the coolant reservoir thats attached to the front grill area? Removed the 10 mm bolt, dont want to break any thing. cheers! Found this on a post from this forum that explains! |
After you remove the one screw, gently twist the reservoir side-to-side and the clips should come free of the support.
yes, it has that little rubber mount and pin and you have to work it out towards the rear of the engine.
Tilt the 'back' of it up and out like it hinges on the bolt you just took out. It will come out.
