How To DIY Requests....
However, only recommended for use on the passenger side when you have no passenger, but something heavy on the seat to set off the sensor. Seat belts can save your life, and hold you in your seat when cornering hard. Wear it.
Hardwiring Valentine 1 ???????
I apologize asking this question, because I know another thread already exists. But, wading thru it confuses my simple mind. So, at the risk of looking stupid, here's my question.......Where do I connect the positve wire of the V1 so the unit turns off when I turn the ignition off, and how do I route the wire so that I can mount the V1 above the left side of the rearview mirror? Thanks.
I need very specific instructions on how to jack a MINI up for tire rotation..
I'll be doing my own tire rotations on my 2010 R55 and am having a hard time finding a full set of very specific instructions on how to lift the entire car up using a jack and jack stands; I've never done it before.
I need step-by-step precise instructions that detail everything from the initial jacking up of the car to placing the jack stands under it, including exactly where to place the jack and all of the jack stands.
Thanks!
Thanks!
LaneCountyMini (07-27-2022)
Then the glossy plastic a-pillar is on tabs similar to interior body panel pieces. You can pop them out, but you may need a good plastic pry tool. Good luck.
on
I dont remember what size, but the front seats require a TORX bit (preferable on a socket) two in front and two in the rear after you slide the seat forward that hold it to the car on the seat rails. There is also a big clip for the electronic area like airbags in the middle etc.
The rear seat is a little more involved. If you start from the boot you should see some torx that are holding the seats where they hinge. Once they are out of that hinge, the other thing holding them in place is a stud that goes into the sides of the car, so you have to pull them towards the center. Just keep looking for bolts and removing them.
If I remember correctly, the piece along the roof trim need to come off first. It slides toward the windshield. There is a tab sticking into the rest of the trim around the roofline.
Thanks for the info. I Google searched it and surprise surprise it found it in the 1st gen forum. I figure it is probably similar as i bought the part and it looks very similar. I didnt end up doing it myself I had the guy doing my windshield do it. The one i replace has very minimal cosmetic damage so if anyone wants it let me know.
I asked if needed to take those trim pieces off and he said yes. So I gave him the one I bought the day before. Looking at the gen one forum I think it would be super easy to do. Peel back the rubber trim seal for the door on the side u need to do. Unscrew 4 screws. Pop pressure clips off and take off the trim. Then make sure the foam strip is good and install new trim piece. Replace screws and rubber and done.
Sorry that was kinda long answer to a simple question.
Has anyone changed the Grill Trim pieces (chrome on stock MSC and JCW) top and bottom?
I want to put the JCW black grill trim. the top part seems pretty straight forward - just a couple screws and it should pop out. The bottom I cannot tell if the entire grill has to be removed with the trim piece or if the trim piece is just force fitted on top of the grill.
Any feedback is appreciated greatly!
In order to remove the grill, you will need to pry the top 4 expanding rivets ( in front the grill) and press the 4 bottom clips (behind the grill) then pull it out from the bumper.
It's pretty much self-explanatory once the grill is removed.
http://www.realoem.com/bmw/showparts...20&hg=51&fg=15
