How To Electrical :: Radar Detector Hardwiring (12v Line) Above the Rearview Mirror...
Old Oct 9, 2008 | 08:48 AM
  #151
phxsteele's Avatar
phxsteele
I am out of town until tomorrow night. I will pull apart the upper console this weekend to see where the dealer wired it and post it here.
Old Oct 11, 2008 | 02:46 PM
  #152
phxsteele's Avatar
phxsteele
I just took it apart and the dealership ran a wire down to the fuse panel on the passengers side floor board. They tapped in the plug in to the front/bonnet side of the panel. The red wire, with black stripe and yellow horizontal stripes. Here is a pic of the fuse panel and the wire they tapped into.
Old Oct 13, 2008 | 06:55 AM
  #153
strobeyprobey's Avatar
strobeyprobey
Awesome, thanks for the post! I was going to use a Buss add-a-line fuse tap for the V1 since I just added a PLX gauge also.
Old Oct 15, 2008 | 08:18 AM
  #154
eg0911's Avatar
eg0911
less than 15min install, v1 is nicely mounted on the right side now, i grounded it with a small screw on the left side into the metal. thanks for the writeup to make the install go super smooth
btw my radar powers off immediately when i remove the key, i followed the same directions so im not sure what i did differently
Old Oct 23, 2008 | 10:30 AM
  #155
maximus96's Avatar
maximus96
i was trying to clip my older Bel 985 to the headliner with the supplied visor clips. however, i wasn't able to clip onto the headliner at all, seemed like the clip was blocked by something and couldn't slide into the other side of the liner. was it difficult for you guys that clipped to the headliner? i don't want to use suction cups and kind of hesitant on velcro because i don't want to leave a fuzzy mess on the liner when i remove the detector/velcro.
thanks
Old Oct 23, 2008 | 05:20 PM
  #156
Minidrivr's Avatar
Minidrivr
thanks
Is the end of the clip for the Bel 985 flat? The headliner is pretty thick. If I remember right it has a plastic edge just above the actual edge you see. So the clip has to clear that too. And the angle is a little difficult. The windshield is in the way slightly too. I had to put the V1's clip at an angle and wiggle it a bit while pulling down in the edge with my fingers.
Old Oct 26, 2008 | 01:30 AM
  #157
donuttang's Avatar
donuttang
thanks, crucial_fiction ..... i got mine done today...however, i took a while to get it to work, coz i blew the F14 fuse so how..and took me some time to figure that out.........:(
other than that, i just used finger to pop the panel out.....no flat screw driver need, no scratch....
Old Oct 26, 2008 | 04:44 AM
  #158
shokk's Avatar
shokk
7th Gear
I definitely blew my F14 fuse. Wrong purple wire. The dealer also has to replace the overhead module as the map lights and visor lights are out and now won't come on. Doh!
Old Oct 27, 2008 | 08:48 AM
  #159
maximus96's Avatar
maximus96
i end up using an add-a-circuit to tap into the 5amp reverse parking sensor fuse since i don't have that option. also end up velcro-ing the radar detector to the headliner. i managed to get the clip inside the headliner but it looks terrible from the front. the edge of the headliner was bent foward and the white color inside clearly visible.
taping to the fuse-block was very simple, i just tuck the wiring inside the rubber strip. detector comes on and turns off with ignition. i'm actually splitting that add-a-circuit three ways, for the detector, auto sport button, and reverse camera. each draws less than 1 amp, shouldn't blow the 5amp fuse.
Old Oct 28, 2008 | 02:50 PM
  #160
iwashmycar's Avatar
iwashmycar
the write-up states LIGHT PURPLE/BLUE but it looks obviously tapped into the LIGHT PURPLE/GREY... hmm. guess ill find out in 5 minutes.
EDIT: Ok i tapped the Light Purple/GREY one, because it looked like a heavier gauge wire, and in the write-up he stated he used the bigger one.....
WORKS GREAT!
thanks!
Old Oct 28, 2008 | 07:55 PM
  #161
shokk's Avatar
shokk
7th Gear
WORKS GREAT!
thanks!
Yep, that was my mistake. Once the dealer deals with the damage, I'll see about getting that wired back in there.
Old Oct 29, 2008 | 08:26 AM
  #162
iwashmycar's Avatar
iwashmycar
yeah i think the 1st post needs changed, unless mini changed wires at some point!
Old Nov 9, 2008 | 04:28 PM
  #163
sgn's Avatar
sgn
12v tap
Curcial Fiction,
First of all thanks for your service to our country! I'm looking at mounting a homelink in the center of that overhead panel with a little trimming, but wanted to know if any of those wires provided constant 12v power to keep the memory in the opener.
Old Nov 10, 2008 | 12:38 AM
  #164
donuttang's Avatar
donuttang
i found that my V1 doesn't seems to turn off at least for 15mins with engine off, key removed? can anyone confirm it will be off and how long? do i have to lock the car first?
Old Nov 28, 2008 | 07:25 AM
  #165
Eric (Plug Guy)'s Avatar
Eric (Plug Guy)
Had to REVIVE this thread based on my current experience.
Would appreciate some advice before I approach the GM of the dealership about this whole thing.
Read my original post here. https://www.northamericanmotoring.co...d.php?t=158800
Since I already have the wiring down to the fuse panel, I'm figuring I'd rather keep it there, just looking for a more problem-free solution a dealer can't hang me on. And the overhead power-on thing would drive me batty, so unless someone has found switched power up there, I'm probably looking to stay in the fuse panel.
Thx.
Old Dec 2, 2008 | 04:56 AM
  #166
SNOTQT's Avatar
SNOTQT
Nice presentation there Mr. Crucial Fiction!
(First posting here)
I am going to install a Whistle remote radar detector and the consol part (which is very small) may fit up above the mirror very discretely using your wiring method.
I installed the remote antenna under the radiator or intercooler and it sit there without any mounting bracket. I couldn't believe how lucky I was to find a place right on the nose of the car where it could fit so snug. (believe me it ain't movin!) So now I need to complete the rest of the wiring so I got on here trying to find a way to get a wire thru the firewall. Any ideas? It needs to end up at the same place as the console (hopefully the rearview mirror)
I have wired many cars but this Mini isn't like most cars. Lol
Thanks again,
SNOTQT
2008 Sparkling Silver S Clubman
Old Dec 2, 2008 | 06:56 AM
  #167
foxy1's Avatar
foxy1
what exactly is this!!
does it detect police or what?
Old Dec 2, 2008 | 07:30 AM
  #168
iwashmycar's Avatar
iwashmycar
yeah its like a good 15-20 minutes but it does turn off... ive had this wired up for a few weeks now and its all good. you do not have to lock the car...you dont even have to completely take the key out. as long as no doors are opened itll stay off, then once you open the door itll turn back on.
Old Dec 2, 2008 | 07:34 AM
  #169
iwashmycar's Avatar
iwashmycar
Thanks again,
SNOTQT
as far as wiring through the firewall, check out the Alta site's gauge install instructions...they show it.
http://www.altaminiperformance.com/p...ory=7&model=11
you can then probably just route the wire behind the A-pillar and tuck it up under the headliner to the console...I've done that many times on other vehicles, but not a mini
Old Dec 2, 2008 | 07:47 AM
  #170
lacning74's Avatar
lacning74
The passenger firewall visible behind the battery is easier. You don't have to remove the wipers, just the the passenger side portion of the rubber trim panel at the base of the windshield. I used it to pass the wiring from the front sensors of my laser jammer. The wires almost just fall down into the passenger footwell. No coathangers needed, just reach your hand up.
Old Dec 2, 2008 | 04:56 PM
  #171
Eric (Plug Guy)
Has anyone found switched power in the overhead that turns off when car is off (instant) yet?
Old Dec 4, 2008 | 08:50 PM
  #172
SNOTQT's Avatar
SNOTQT
Thanks for the advice!
Hopefully get this taken care of over the weekend.
Old Dec 11, 2008 | 06:56 PM
  #173
BigOly's Avatar
BigOly
Very nice!
That's a great idea! I would hate to splice into any factory wires on my newly purchased R56/09, "add-a-circuit" seems like the way to go for me too.
Would you happen to remember the letter/number of the fuse to the 5amp reverse parking sensor fuse? I plan to do what you did...radar, sport mod, etc... on one 5 amp fuse... Thanks!
Oly
Old Dec 11, 2008 | 07:45 PM
  #174
lacning74's Avatar
lacning74
Oly
F30. Check out the "hot or not" sticky in this electrical forum. With all my accessories, I'm thinking of wiring into the battery directly with a dedicated fuse block with an ignition relay.
Old Dec 11, 2008 | 08:47 PM
  #175
toolazyforalogin's Avatar
toolazyforalogin
Lacning you are a wiring addict indeed.
