How To Suspension :: H&R Springs Install
#76
#77
Now if you have a reason you want more or less camber for other reasons, that's a different story...
#78
That is great!! My alignment guy only charged me for the front, which came out fine but he said that there was no room for adjustment to remove the negative 1.8 degree rear camber I now have. He must have been wrong so I will go to another mechanic to see if we can shove them in a little. I am not picky so just eyeballing it will do for me.
Other than this minor glitch, I love my H & R springs.
Question: Is the bolt for adjustment the one closest to the wheel or the muffler or both??
#79
#80
Sorry I may have missed something. The OEM arms DO have Camber adjustment built in to the lower ones. They started being installed on the late 06 models and continued through the R56. If you need more correction that the oem adjustment allows I do suggest the ALTA versions!
#81
The distance between the attach points in the middle vs at the wheel might be different. The camber needs to go more negative as the car leans on that wheel, IMO, to maintain traction. Otherwise the car would be riding on the outer edge of the tire rather than the whole surface of the tire.
#82
#83
I could see that going quickly around a corner, but I wouldn't want to be riding down the highway with the wheels tilted that much.
ToMITa - was the alignment up front able to correct for that condition?
Adam - do you know how much the stock arms can take out of the rear?
#84
Good point about "centrifugal force". I never thought of it that way. My alignment guy could not correct it but I am thinking maybe he didn't try hard enough. Anyway, I will correct it when I get the arms. Hope I didn't jump the gun buying them but it will be a nice addition to the car. The front end is okay.
#85
on
#86
I just crawled under the car and didn't see any possible adjustment. I thought maybe there'd be an eccentric bolt (right term?) but didn't see one. So it seems like the only possibility would be how much larger the hole is than the diameter of the bolt. I hope I'm wrong because I'm not anxious to spend another $225 for a set of control arms.
I don't track my MINI (or haven't yet), so I really don't need sophisticated changes, just closer to stock camber with the drop.
And with progressive springs, I guess the compression will be quicker than stock from jump street, making matters worse...
#87
Don't know, all of our newer cars, were lowered, and our control arms went right on. Sorry! I don't think that there is enough to eliminate the -1.9, but i would guess you could take out 1 degree. Which would leave you in the -1 degree range, and i think this is very acceptable. But that is just speculation on my part. For sure, our control arms will work to get you back to zero, and get rid of some rubber bushings.
BTW, In that picture above, you can see the bolt that is adjustable.
#88
#89
So just to be sure, ToMiTa's negative camber is a pretty unique case right? I'm planning to lower my MINI with the H&R springs after Winter is over. However I don't plan to purchase the ALTA control arms, but at the same time don't want to mess up my handling or have uneven tire wear. So when you say 'our' are you referring to the stock ones or did you install the ALTA control arms on all you guys' newer cars?
#93
#94
Be tough to get any accuracy in alignment, though. I think I'll try rotating that collar 180 degrees when I put the springs on and see how that does. If it's not enough, I'll bite hard and invest in adjustable arms.
It was mentioned that there are other advantages to them other than adjustment (like no rubber bushings). How does that help or affect ride quality? What is the reason for having rubber bushings on the stock arms?
#95
Graham got his Rear Control Arms installed today. They work great and look cool. I had the mechanic set them at -1.0 for now.
All is as it should be. I will post pic when I get time to take one.
BTW, The factory arms are made out of galvanized steel. I stuck a magnet to one to check.
#96
#99
#100
Hey Adam, a few questions. The Privat Netz are listed on the ALTA site as available in both 17 and 18" sizes, but it only gives one price, and I don't see any place to specify which size I want. I'm guessing $149 is for the 17's. What's the price on the 18's, how much do they weigh and what's their width? I'm looking to get them in gloss black within the next few months, around the same time I plan to install the H&R springs. Also, if I order the wheels straight from you guys is there any way to get a wheel/tire combo? I know your set is 17" but what brand and size tires do you have on Howard?
THANKS
THANKS
