How To Maintenance :: Cooper S Oil Change (with pics!)
Old Apr 11, 2010 | 03:44 PM
  #451
Silver57's Avatar
Silver57
Great instructions, thank you.
First oil change at 6k!
Old Apr 27, 2010 | 05:12 PM
  #452
miniinhd's Avatar
miniinhd
Air Filter Replacement With pictures
Hello Mini Gang for us new folks hows about pictures to show us how to replace the air filter on 2nd generation minis THANKS MINIINHD
Old May 14, 2010 | 01:20 PM
  #453
ElNino's Avatar
ElNino
Does it matter which way the filter goes into the housing? Both ends look the exact same to me.
Old Jun 12, 2010 | 04:41 AM
  #454
CMG's Avatar
CMG
really easy to do, I did buy a new oil drain plug http://www.partsgeek.com/catalog/200...rain_plug.html
The bolt has an attached forever rubber grommet, safe to assume I no longer use crush washer? it would no longer crush, just sit in the grommet.
Old Jun 25, 2010 | 11:21 AM
  #455
toolazyforalogin's Avatar
toolazyforalogin
Just did another oil change this morning at 37,000. Piece of cake - thanks again.
Old Jul 9, 2010 | 09:47 AM
  #456
minimini482's Avatar
minimini482
I am about to do my first oil change on my 2010 JCW and I have some questions for those who have done a couple oil changes:
When moving the coolant reservoir tank, do I need to remove either of the hoses connected to it or is it OK to just bend them to get the tank out of the way? My fear is that the hoses will come loose and leak...
(FYI: I have a 2010 JCW and the bolt holding the tank in place is a 10mm - the OP mentioned 8mm on his; perhaps the size changed since '07?)
I test fitted some Rhino ramps and noticed the black plastic air dams (is this what you'd call them?) will rub slightly - has anyone run into any issues with the plastic cracking when driving up the ramps? They seem flexible enough so I may just go for it, but wanted to see if anyone here has had any issues with this?
Thanks in advance!
Old Jul 9, 2010 | 09:55 AM
  #457
skippydog's Avatar
skippydog
Its very easy. Just unbolt and move to the side. No need to disconnect any lines.
Old Jul 9, 2010 | 10:15 AM
  #458
ronnie948's Avatar
ronnie948
Be careful when using the ramps.
They do want to slide when trying to drive the car onto them. Be really careful of this.
I don't use them anymore. I have a couple pieces of two by eight boards that I made ramps only four inches high that I use. They raise the front of the car high enough that reaching the drain plug is no problem at all.
Old Jul 13, 2010 | 10:30 AM
  #459
Uncl3's Avatar
Uncl3
What are the torque settings for filter cap and drain plug?
Old Jul 13, 2010 | 12:46 PM
  #460
Porthos's Avatar
Porthos
Well no ramps for me just a 3 ton jack and some jack stands. But I have a question of how to get the tranny fluid back in. With out pics I really didn't understand and I am about to do my oil, brakes, and tranny fluid this weekend and fix some other varios tid bits around the MINI.
Old Jul 13, 2010 | 07:30 PM
  #461
toolazyforalogin
oil pan drain plug = 22 lbs/ft torque 8 mm hex
oil filter cap = 18.5 lbs/ft 27mm or 1 1/16
tranny fluid is lifetime Porthos. It should say it right on the drain plug.
Not to sound like a di¢k but did either of you bother to read the first 12 pages of this thread?
Old Jul 14, 2010 | 07:31 PM
  #462
minimini482
I just finished changing my oil for the first time. It was super straight forward - largely due to this thread. Thanks to all who have contributed!
FYI- after just over 2300 miles the oil was very black as others have reported here. For the money it is well worth doing the change IMO.
Old Jul 15, 2010 | 03:14 AM
  #463
richardsperry's Avatar
richardsperry
Color has NOTHING to do with anything...
Old Jul 15, 2010 | 08:35 AM
  #464
Porthos's Avatar
Porthos
Yes I read it and yes I know it is lifetime but at the time I had an oppurtunity to get better fluid and that fell through because it was the wrong stuff. I ment to put on there how to put the fluid back in the tranny. I would like smoother shifts and the stock fluid doesn't do it. Plus nothing is lifetime. It would eventually need to be changed.
Old Aug 11, 2010 | 08:37 AM
  #465
DavidBauder's Avatar
DavidBauder
if it's like my 04' mini oil filter, one end of the filter is a larger diameter than the other so it can only go in one way.
Old Aug 11, 2010 | 08:55 AM
  #466
minimini482
for '07+ models it does not matter what side the filter is installed. It should click or pop into the housing however.
I read the above on this forum and when i last changed my oil I tested both sides before installing
Old Aug 28, 2010 | 05:37 PM
  #467
Mekidon's Avatar
Mekidon
I just did the oil change and drove back home.
I checked my dipstick and there seems to be oil on the top notch (Max), maybe even a little on the metal part.
Should I be concerned?
The guy who insisted on helping me out put in 4.6 qts when I told him 4.4 qts.
I called a mini service adviser to double check, and he said between 4 and 5 qts.
I checked the dipstick again after driving 20 miles home, and it was still at the same level.
What should I do?
Old Aug 28, 2010 | 08:20 PM
  #468
slinger688's Avatar
slinger688
Should be fine. I would not worry.
Old Aug 29, 2010 | 06:19 AM
  #469
CMG's Avatar
CMG
agreed
Old Aug 30, 2010 | 03:58 PM
  #470
jeffgrice's Avatar
jeffgrice
Great article!
Just bought a preowned clubman s and am preparing to change the oil.
Bought the NAPA/Wix filter and in addition to the expected rubber O ring was a small copper looking ring (3/4 inch). What is that for? Didn't see it in your pictures?
Thanks.
Jeff
Old Aug 30, 2010 | 04:05 PM
  #471
richardsperry
Drain plug crush washer
Old Sep 6, 2010 | 06:56 AM
  #472
jeffgrice's Avatar
jeffgrice
Just completed my first oil change on the clubman S. Instructions were perfect - thanks!!!
A tip. I also rotated the tires at the same time.
Had the car hot. Did the drivers side (cleaned the wheels at the same time).
Did the passenger side.
Left the passenger front off.
Very easy access to the drain plug. Drained the oil. R&R the filter. Bolt back in the pan. Last tire on.
So since I like to rotate tires at the same time I change the oil (every 6-7k miles) this really makes getting at the drain plug a breeze.
Best,
Jeff
Old Sep 6, 2010 | 07:32 AM
  #473
richardsperry
So does having a lift in the garage...lol
Old Sep 12, 2010 | 04:33 PM
  #474
sunman's Avatar
sunman
pretty good wirte-up on how often to change the oil in your car...
http://finance.yahoo.com/news/Like-t...pf-family-home
Old Sep 17, 2010 | 11:33 PM
  #475
fishbert's Avatar
fishbert
So, the other day I picked up some Pennzoil Platinum Full Synthetic 5W-30.
The bottle says: "meets or exceeds the requirements of API SM, ILSAC GF-4, ACEA A5/B5-04"
The website goes on to say:
  • Exceeds API SN and all previous categories; ILSAC GF-5 and ACEA A5
  • Exceeds API SL/CF, ACEA C3, A3/B4-04 and A3/B3-04
  • Meets BMW LL-04
With a note that "specifications met vary by viscosity grade."
Why am I mentioning this here?
$3.99/qt at Checker Auto Parts until Sept. 28th
