New to Oahu from Maui
Old Jun 12, 2017 | 09:43 PM
777madmax's Avatar
777madmax
Aloha!
Just moved over to Oahu for work. Looking for any suggestions for a good shop for maintenance here since I can't do anything at my new place. Thanks a lot.
Also, I got a Blue 04 MCS with white top so throw shaka if you see me between town and Kapolei!
-Max
Old Jun 14, 2017 | 11:49 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
If for just regular maintenance there are many independent shops that can do the work. Your MINI has been out for many years so basic stuff is straightforward.
Just call around, check yelp for reviews. BMW shops will work on MINIs no problem but rates may be a little higher.
The dealership rates are very high and not required for just maintenance stuff.
What work did you want done?
Old Jun 14, 2017 | 07:05 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Welcome looks good.
Ask around the MINI club I know they have a couple guys that do good work that get parts from us all the time.
Old Jun 14, 2017 | 10:08 PM
777madmax's Avatar
777madmax
I know the 1st stage cooling fan isn't working so replacing that for this traffic. Then probably supercharger oil change cuz I don't think thats ever been done either (almost at 123k). Thats all I know needs to be done but I kinda want a expert to check it out. Possibly other small maintenance stuff/fluid changes for piece of mind. Mobotech maybe?
Originally Posted by WayMotorWorks
Welcome looks good.
Thanks! Good call, I should definitely see if anyone can help me out
Old Jun 17, 2017 | 12:08 PM
minihune's Avatar
minihune
Supercharger oil change is lots of labor- consider doing water pump at the same time.
https://www.northamericanmotoring.co...ge-how-to.html
Mobotech seems OK- just ask them about working on MINIs.
https://www.yelp.com/biz/mobotech-auto-honolulu-2
You can ask Way at WayMotorWorks about things that need to be checked and replaced for your age and mileage.
Usually most of the suspension joints and bushings are worn out.
There is a MINI club, check the other threads
Old Jul 23, 2017 | 12:49 AM
Hnhel07's Avatar
Hnhel07
Looking for a shop
Hi guys this is Rudy, I've been in oahu for about 5 months, I'm having issues with my mini there's a noise coming from the engine it may be the water pump or supercharger. The car still runs but not as smooth as it used to. Im looking for a mechanic that works on Mini's or a reputable place that's not as expensive as the dealership. I live I Ewa Beach, any help is appreciated. Thanks in advance.
Old Jul 23, 2017 | 01:43 AM
reydio's Avatar
reydio
Rudy, close to you is M-Tek Auto Care. He works on BMW and Mini's.
http://bmwrepairhawaii.com/
Bring your car for assesment.
Old Jul 23, 2017 | 12:42 PM
Hnhel07's Avatar
Hnhel07
Thank you for the help reydio. I'll give it a try.
Old Aug 6, 2017 | 09:49 PM
minihune's Avatar
minihune
Let us know if that works for your repair
Old Aug 7, 2017 | 02:28 AM
mparkmc's Avatar
mparkmc
Shop for Mini in Honolulu
Mobotech is a fine shop
Victar the owners know MINI s well, he has a R53 stage 3 and a classic Mini.
He has been working on my R52 S JCW for the last 4 years does good work.
Local MINI club seems to be off again after a 3 month active meets.
If you see a R52 top down with a single silver stripe on bonnet and boot, silver union jacks down the sides and a union jack wind deflector give a wave back, they are rare now days
