Is there a GP "kit" and a factory GP?
i tried searching around but couldn't seem to find much info on this.
I'm currently looking at two 2013 GPs to purchase and although they look identical i did notice different listed weights.
The first GP shows :
02-2013
GVWR 3108 LBS 1410 KG
GAWR FRONT 1830 LBS 830 KG
GAWR REAR 1345 LBS 610 KG
stock 1673T
The second GP shows:
06-2012
GVWR 3527 LBS 1600 KG
GAWR FRONT 1929 LBS 875 KG
GAWR REAR 1676 LBS 760 KG
stock 1070P
I don't know if this means only one is legit or not but this raised a red flag to me. I see the build dates are different but the second one i listed seems to share the stats of a non GP JCW.
Any help would be greatly appreciated.
02-2013
stock 1673T
06-2012
stock 1070P
Buying two ?!
No kits.
Would seem one of those listings has garbage for stats, that's all.
Are you starting a race team, or is this just the easiest way to keep your significant other happy ?
Weight differences of that amount is usually attributed to transmission type but the GP's are stick.
No kits.
Buying two ?!
No kits.
No kits.
Run the VIN of both cars into this decoder: http://bimmer.work/. It will list the factory options on the car. A GP should be listed with Option 7KH "John Cooper Works Gp" (I tested it with the VIN of a 2013 GP for sale on the web).
Perhaps the 06-2012 car was loaded up with GP cosmetic parts: http://www.motoringfile.com/2013/06/...to-the-jcw-gp/
So what you are saying is that you are physically looking at their respective factory window stickers, and both documents indicate GP, but both have conflicting data with respect to weight ?
That is odd.
When shipped even the tires were the same, they were only swapped out at the dealer, other than that data and cars were "cookie cuttered " to US, 2000 cars.
That is odd.
Do you mean 06-2012 production date? There is something wrong with that. The R56 GP did not begin delivery to customers until 2013 (you can Google this). The GP has a different suspension from the S and will have a different GVWR/GAWR (which by the way is not weight of the car but the maximum allowable loading weight).
So both do in fact have the "7KH" listed under options so I'm guessing that's a good sign. I'm not sure why the weight sticker is different but if it's max loadable weight it's pretty much a non issue. I'm just not sure why they would be different.
Another point you made was the maufacture date. I have been trying to look at other GPs for sale and I see one at dutchess county in NY and that has 11-2012 on the label. Is it possible the earliest ones had 2012 dates but sold in 2013?
I know it was pretty easy to spot a cooper S with a JCW performance kit vs a factory JCW but I just wanted to make surethere was nothing like that with the GP. I guess looking at all the GP parts/trim if would be even more expensive to make a fake one.
Overall, it's very expensive to put together a complete fake GP (Recaro seats, rear diffuser, wheels, brakes, rear seat delete, etc) and a fake shouldn't be hard to spot.
[QUOTE=rkw;4294805]Yes, the GP2 had its debut in late 2012, although customer deliveries didn't begin until 2013. 11-2012 is reasonable but 6-2012 is strange. Does the VIN decoder also show that as the build date?
yeah the vin decoder shows the same:
Type SU93
Model John Cooper Workjohn Coos - USA
Development Code R56 (JCW)
Chassis COUPE
Steering LL
Doors 3
Engine N18
Displacement 1.60
Power 155
Drivetrain FRONT
Transmission MECH
Color Thunder Grey Metallic - B58
Upholstery Sonderpolsterung - Z1XX
Production Plant OXFORD
Production Date 2012-06-28
and under options it does have : 7KH John Cooper Works Gp
and i agree it should be easy to spot a fake but you never know. the body kit, paint and stickers would be easy to do but it has the dash with the red trim, rear red bar in the back etc. Going through all of that trouble to make a fake would be too time consuming and expensive. literally the only thing that thew me off was the build date and load weight. The seller didn't specify what number it was (i.e. #93 of 500) nor does it have the roof sticker but that seems to be 50/50 that sellers state that info. GPs for sale here on the forum i see its always stated, dealers I've never seen it stated, and private sale outside of here its hot or miss.
i really appreciate all the info and help, i wouldn't be able to get these answers by myself.
Type SU93
Chassis COUPE
Steering LL
Doors 3
Engine N18
Displacement 1.60
Power 155
Drivetrain FRONT
Transmission MECH
There were definitely changes over time during the GP2 production - so if that early really is just a very very early build GP2, perhaps the weights simply changed due to changes.
For example, some GP2s have the stereo "fader" for front/rear level adjustment enabled - and it fades between the upper/lower speakers in the doors. There are other changes across the span in the stereo system as well.
Perhaps they changed other details like sound deadening or something that would have obvious weight impact.
Honestly I'd think a fake GP2 would be easy to spot - pop one of the taillight access panels and look inside. Is it Thunder Grey inside? (and since TG was only on the GP...)
You've have to be pretty dedicated to repaint the interior. OTOH, to fake a GP2 you'd also have to cut metal out of the inside (you have to remove the rear seat latch mount arm to fit the GP2 side panels) - so if you had half or more of the interior apart anyway, maybe you'd go ahead and respray it.
