How low can the GP be lowered on the stock suspension?
Old Aug 19, 2013 | 03:49 PM
grymni's Avatar
grymni
This past weekend I was going to lower the passenger side rear of my GP to match the drivers side. The passenger side sits about 1/8 inch higher. After taking the rear wheel off I noticed there were only a few threads left of adjustment. My question is for those of you that have lowered your GP's all the way what is the measurement from the top of your wheel center cap to the lip of the wheel well?
Old Oct 15, 2013 | 07:19 PM
GOAZFGP2's Avatar
GOAZFGP2
I just found out as well today and I was planning on go lower to buy a set of KW v1s
, have you lower it yet? If so send me a picture or post it here
Old Oct 16, 2013 | 02:38 AM
robbo mcs's Avatar
robbo mcs
I use the measurement from the lip of the rim at its lowest point to the bottom of the plastic of the wheel arch. This is the best measurement as it is independent of tire size or pressure. Most other measurements will vary slightly with tire pressure, and quite significantly with tyres.
Using these measurements, fully lowered I have 560mm front and 565 rear. This needs to be measured on a completely level concrete slab. Even floors that look flat but are just a tiny bit off can throw it out a lot. If in doubt turn the car around and measure in the same spot parked the opposite direction to see how much change there is. Also it is not that scientific as the body panels are not perfectly aligned etc
Adjusting the fronts is very easy. The rears are a major PITA!
Robbo
silence2-38554
Nov 12, 2015 09:39 AM
theblackfalcon
Oct 11, 2015 09:49 AM
Emnotek
Aug 13, 2015 05:47 PM
Minibeagle
Aug 13, 2015 10:00 AM
