GP Rear Spoiler
GP Rear Spoiler
Have any of the new owners taken a good look at their rear spoilers? How does it attach around the glass?
If someone could take a picture, or two or three, I'd really appreciate it.
Just want to see if it's possible to add one, but keep the current back glass on my JCW.
Lot's of info says you have to buy the kit with the back glass, but I've seen pictures of the early mules, and they've got rear wipers, etc.
There are two companies that make a GP style rear wing, neither of which require removal of the rear glass: Fubrication, and Orranje. I have the Orranje wing, and they recently started making them adjustable, it's a good piece, but the Fubrication wing looks great too.
If it's cosmetic, up slightly above the roof line looks best. If it's function, it needs to go slightly below--doesn't look as nice, but if you look at the wind tunnel video of the new GP, you can see why they lowered it about an inch.
on
The GP rear wing does require you to buy the glass. It has a proprietary mounting system that incorporates the mount with the glass. I had a really good look at it this morning after my MA mentioned it. Save yourself some money and buy the aftermarket ones. The OEM MINI GP wing will set you back $2K. I think Fubrucation has theirs for around $600.
Went by the dealer to take a look at the GP today. Very nice. Took a very good look at the spoiler, and it really doesn't look like I need to do the glass, too. I know that's what the MINI Genuine Parts UK website says, but it appears to be an easy swap. And, the spoiler really looks fantastic live. Very nice.
Hey KF.
I took a good look at it just now and took a few pics- doesnt appear to have any special glass at all with regards to the spoiler. The GP does have a different glass than a standard R56 because of the rear wiper delete... maybe that is where the GP specific glass hooplah comes from?
It looks like the side uprights have a clamping system that has 2 torx bolts that pinch a "U" channel sleeve that secure them to the glass.
I did notice that the top fascia is contoured to incorporate the rear spoiler- probably something that the aftermarket kits do not offer...
hope this helps.
good luck.
hope this helps.
good luck.
GP1257.
As I thought- this is untrue. I removed my spoiler to get the facts rather than rely on heresay.
The spoiler supports mount to the glass using a removable "C" channel bracket. The top secures to the roof just as a standard spoiler would mount- to the hatch using 5 10mm nuts.
Pictures are worth a thousand words so here we go:
removed these 4 torx nuts first- two per side:
remove the rubber caps to get to the 10mm nuts
here it is off the car:
side/upright support brackets
mini decal for reference:
hope this helps
aabcds (09-13-2018)
on
I can get the rear spoiler from my dealer. The issue I have are the little metal flange things that are taped or glued on to the glass and part of that strip in the pictures above.
It's not special glass, but if MINI won't sell those things separately, then buying the rear glass maybe the only way to get them. I can't seem to find a part no. for those pieces. They are the ones in the 2nd and 3rd pictures from the end above.
on
I had the JCW CF wing on my 2012 MCS and ended up selling it a while back. Just not happy with the look. It was a straight up install, exactly like the photos show the GP2 wing in this thread. When I saw the GP wing I was in love! Far be it for me to let a little money stand in the way of getting what I want for my car! Saw the red-stripe JCW R-113 wheels and bought them a year ago and mounted them up to Michelin SS's for my summer wheel/tire combo.
I should know the answers to some of these questions within a week or so. I ordered the GP2 wing last week from my dealer. Coming from Germany and should be stateside sometime this week and then has to be shipped to my home in Michigan. Part# 51627341933. I doubt it will come with the C-channel mounting brackets. I ordered up some 3M commercial 1/2 wide double sided tape for mounting automotive exterior trim pieces. My intent is to run a strip on either edge of the rear glass the same length as the C-channel to rest the supports onto. I don't see that attachment point as being critical to the install, as with speed, the wing would exert downward pressure to the supports pushing them tighter onto the back glass surface. I've also sourced a company in Michigan that makes plastic fill caps for many different sizes of access holes. Once I have the wing, I will measure the diameter of the support bolt holes and buy four caps that will pop into the empty holes. More to follow when I get the wing.
on
That's great. Keep us updated. My dealer is ordering the rear spoiler for me tomorrow. It's in Germany, and I'll get an ETA next week on when it should get in. I like the double-sided tape idea. Figure we should be able to fashion something back there to mimic those metal flanges if we can't buy them separately from the glass. I want to keep my wiper.
If I was you I would save your money and go for an aftermarket one like the Orranje G-Wing, its probably not even a 1/4 of the cost of the genuine part, but looks just as good. They are also finishing off the work on an adjustable version too.
http://www.minitorque.com/forum/f754...260-p-p-29407/
Theres no need to change the rear glass, unlike some of the other replicas and the 1st gen original, their wing was designed to fit around the standard glass.
on
This confirms what I was thinking based off some other pics I saw. The idea I've been toying with is making a mounting bracket that runs over the glass like the oem, but mounts to the inside of the hatch like the aftermarket spoilers. This would eliminate the need to even remove the glass at all and allow the use of the oem spoiler which I think looks much better then the aftermarket ones who's design is still based on the GP1.
Hey Mike: Why not just duplicate the OE mounting bracket that slides over the edge of the glass? Unless I am missing something, I don't see the need to have it mount to the inside of the hatch. All it has to do is ride over the edge of the glass to allow the support bolts to go through the holes and thread to the support.
