Getting the GP ready for MOTD....
on
The GP is currently at the shop, having a Autopower Industries Race Roll Bar and Schroth 4-Point Rallye Cross Harness installed. After speaking with the Owner of the shop yesterday, to check how the progress was going, and asking him to check the suspension, mainly the Tie Rods and Ball Joints for wear, I was told that the Right-Side Tie Rod was really bad and would need to be replaced and an alignment done. I authorized them to replace the Tie Rod. After sending that E-Mail, he E-Mails me back saying that a Tech was putting the rear wheels back on and then went around and re-torqued all the wheels but in the process of torquing the wheels, he found 2 loose lug nuts and one had stripped threads!! Which I don't understand because I had torqued all the Wheels to MINI Specs and this was not my first time putting wheels on a vehicle and torquing them. He said they would try to Helicoil the Stripped Thread but if they doesn't work, then I would need to replace the Wheel Hub..
Point of this Thread?.... I'll be going down to NC for MOTD and getting the GP ready for the Trip is starting to add up. Hoping they don't find anything else wrong with the GP!!
In April, before I head down to MOTD, I'm also going to have 4 new tires mounted and balanced on the OEM GP Wheels and a Oil and Lube job done. The GP is close to 50K Miles, so I ask, what else should I take care of on the GP, before I go to MOTD? I've already installed new front Rotors and Pads, except I'm probably going to change the Pads because I installed Hawk HPS Pads and am not quite liking them, especially in wet weather, so I will most likely install the OEM Brake Pads. Going to install new Wiper Blades, Air Filter, Cabin Filter, Fuel Filter, and change the Transmission Fluid. If I'm missing something, let me know.
By the way.. Any other GP owners going to MOTD?? While I'm down there, I'm having some goodies installed by WAY from Way Motor Works. Having a Stratmosphere Cat-Back Exhaust, Way Motor Works 17% Supercharger Pulley Kit, and a New-Man Camshaft Installed. Can't wait until the last week of April!!
-Adam
-Adam
on
Sweet
I'm currently in Virginia, going to head down to Orlando for a week and won't be home until week of April 19th. I was in Maryland this last week. Sucks not being able to drive the GP!! I've got an appointment set up when I get back the week of the 19th, to have Oil Changed, Brakes Bleeded, Manual Transmission Flush, New Tires Mounted and Balanced. I'm going to Install Carbotech 1520 pads Front and Rear. My Cobra Suzuka Pro GT seat should arrive soon along with the Mounting Hardware, so I'll swap the Recaro Pole Position for the Cobra Suzuka Pro GT.
Can't wait to see some other GPs at MOTD :-D
BucksCountyR57
R57 :: Cabrio Talk (2009+)
11
09-30-2015 02:11 PM
