Jaciking up my Mini
Old Sep 9, 2023 | 08:33 PM
DFH1's Avatar
DFH1
Jaciking up my Mini
Hello- Could someone post or send me a picture of where a floor jack would be positioned at either the front or rear to allow both wheels off the ground. I want to jack up both wheels at the same time so I can position jacks under the jacking points under the car. thank you so much!!!!
Old Sep 10, 2023 | 02:09 AM
Onizukachan's Avatar
Onizukachan
If you jack up from the front jacking point you’ll get one side completely off the ground, so make sure you chock the front wheels, cause I’ve even gotten three (front and both rears) off the ground that way.
Old Sep 10, 2023 | 02:31 AM
Smizrahi's Avatar
Smizrahi
Jacking points from my repair manual
Old Sep 17, 2023 | 09:01 AM
garry sharp's Avatar
garry sharp
Well the manual is the holy book of all repairs as they say
Old Sep 17, 2023 | 09:52 AM
Fly'n Brick's Avatar
Fly'n Brick
Cut a 2X4 to fit between the 2 jack points, balance it on the jack and run it up between the jack points and up she goes. A gone now member posted several demo pictures in a thread he called "How a 2X4 lifts a MINI".
Old Sep 17, 2023 | 01:41 PM
PRM00's Avatar
PRM00
Here's a video
Old Sep 17, 2023 | 02:58 PM
Jason Cornelius's Avatar
Jason Cornelius
For gen 1 and 2, haven’t had the chance to play with a 3 yet, if you look at the front mount, about a foot In towards the exhaust it looks like a box frame. Use a piece of wood or rubber, on pad, place jack just enough behind the front jack point to get your jack in, and raise from there. It will raise whole side of the car, rinse and repeat. Whatever side I start with, I go back and lift it back up just enough to make sure jacks haven’t moved. Have used this method for years no issues.
DFH1
Nov 4, 2023 05:51 PM
Jandreu
R55 :: Clubman Talk (2008+)
Dec 21, 2013 06:22 PM
Cobrabud
Sep 10, 2013 08:35 AM
corliss hale
Jun 18, 2013 10:24 PM
MINI.S.E.MI
Tires, Wheels, & Brakes
Aug 18, 2004 06:21 PM
