My R53 is not doing good!
Old Mar 30, 2019 | 05:25 PM
l_danner@outlook.com's Avatar
2003 Mini Cooper s r53
140000 miles
I just replaced the clutch and flywheel with a Valeo kit. I did all the work myself but followed the video from mod mini to the T.
The car has also not been started in about 3 months.
the video is from startup and a brief run time, the engine revs very high during start up (I did not press the gas) and idles very rough and low rpm. 500 or so and bounces around. I have not driven it, only started it very briefly.
The codes I can pull are.
P1109- manifold air pressure too high in deceleration
P1242- secondary upstream manifold air pressure sensor to high in deceleration
P1689 electronic throttle control monitor level 2/3 torque calculation error
p0445 evaporative system leak detected (gross leak/ no flow.
My quick web search makes me believe that it might’ve an O2 sensor or MAF. But I’m not sure, any help would be greatly appreciated!
Old Apr 1, 2019 | 10:40 PM
Dan_in_WA's Avatar
Dan_in_WA
Do you have a service manual? If not, that would be my next step.
At a quick glance, I’d look for something left either unhooked or crossed up with something else.
Weird stuff can happen when you’ve been that far into your car. A long time ago, I helped a friend put a new clutch in his Mustang. Just before we fired it up I found the throw out bearing sitting on the bench next to my beer!🤬
Dan
Sullosar
Jan 24, 2011 07:22 PM
checkercoop
Dec 12, 2007 07:31 PM
o-ron
Mar 30, 2006 04:47 PM
parzifal
Jul 7, 2005 09:36 AM
Moneypenny
Feb 2, 2005 02:56 PM
